04-25-2007, 03:30 PM
#1
would the map sensor being bad cause 3 cylinders on one side to miss fire? i gettin codes that cylinders 2 4 and 8 are miss firing (something about injector circuits) or would it be something with the ECU?
i put a test light on the injectors and they are getting power.
04-25-2007, 05:41 PM
#2
No
What do the plugs look like? WHAT year and engine do you have!
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
04-25-2007, 05:57 PM
#3
Originally Posted by greasefingers
No
its a 96 limited grand cherokee with the 318 (5.2L). the plugs are covered in gas due to it miss firing.
04-25-2007, 06:16 PM
#4
I would start with a general tune-up: wires, plugs, cap, & rotor.
Cheers Steve
04-25-2007, 06:22 PM
#5
it has all that new along with fuel filter. i got it scanned today and it said MAP sensor HIGH INPUT and something like cylinder circuit mis fire in cylinders 2 4 and 8.
04-25-2007, 06:31 PM
#6
You should have included all the inforamtion in the first thread then.
Cheers Steve
04-25-2007, 06:32 PM
#7
Well that’s really weird because the intake manifold is the same pressure everywhere under there. So if the MAP is bad then why would the PCM only respond well to one side and not the other? I guess you have to replace the MAP and see. They are cheap.
Cheers Steve
#8
ok i think these are the codes it pulled:
P0204: injector number 4 control circuit.
P0206: injector number 6 control circuit.
P0208: injector number 8 control circuit.
and i think the MAP sensor code was P0108
04-25-2007, 06:34 PM
#9
100 bucks isnt cheap in my book! lol
what is a control circuit for an injector? ive been searching through my haynes manual and cant find anything about it
#10
For some reason, maybe MAP related, it appears that the PCM is leaving the injectors open too long and causing a Rich condition.
Cheers Steve
04-25-2007, 06:37 PM
#11
You can get a MAP for your model for $ 61 from rockauto: http://www.rockauto.com/catalog/x,ca...,parttype,5124
Cheers Steve
04-25-2007, 07:04 PM
#12
PCM? is that that computer? do u kno where the injector control circuits are located?
04-25-2007, 07:55 PM
#13
Yes ecu (electronic control unit) = pcm (powertrain control module) = computer
What do you need to know about the injector circuit? The pcm uses many sensors to determine the duration (hold-time) of each injector. The circuit is difficult to discuss over the WorldWideWeb. Basically, the injectors always have power supplied and the pcm grounds the circuit. The computer can be considered a digitally grounding switch, among other things.
Cheers Steve
04-25-2007, 09:28 PM
#14
so basically your sayin to change the map sensor 1st and if that doesnt work then try the ecu?
04-25-2007, 10:14 PM
#15
Pull some of the other plugs and take a look at them. A bad MAP sensor would make all the cylinders run rich, but not necessarily rich enough in each cylinder to create continuous misfires in every one of them. I'll bet the other plugs will have sooty carbon deposits indicating a rich mixture also.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
