MAP High Voltage - P0108 - JeepForum.com
post #1 of 16 Old 11-12-2006, 08:45 PM Thread Starter
lbrty9
I'm getting an intermittent P0108 code. IT'll show up and then the check engine will go out for a while (several days to several weeeks). It did die on me the other day and threw this code as well.
I'm considering having the dealer diagnose this, but the check engine light isn't currently on and I'm not sure if the code needs to be continuous or not.
Any ideas? I'd had to shuck out $150 for a sensor I don't need, I'd hate even more to replace a PCM I don't need!
99 WJ with 4.7.
99 GC, 4.7, 6" Clayton's LA, 315/75/R16's, FIPK, 3 inch Kolak exhaust, VIAIR 450 OBA, front ARB with Warn HS9500, Kevin's Sliderz, full skids, SURCO, Hi-Lift, Xenon's with Kolak harness, more to follow.
lbrty9 is offline
post #2 of 16 Old 11-13-2006, 06:15 AM
greasefingers
greasefingers's Avatar
1994 ZJ
MAP Sensor Testing
Remove the connector at the MAP. There are three pins inside the connector (in a straight line). With the Key positioned to “On”and not start, you should see 5 volts across the outer two pins. This means that the PCM and wiring harness is good.
Reconnect the MAP sensor. Back-probe (with a paper clip) the center pin and connect the other end of the voltmeter to ground. With the ignition key On and the engine not running the voltage be 4 to 5 volts. Start the engine. The MAP should measure sometime 1 to 2 volts. Now open the throttle a bit and the voltage should increase with increasing rpms.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 16 Old 11-13-2006, 07:47 AM Thread Starter
lbrty9
Thanks, that helps a LOT!!!
lbrty9 is offline
post #4 of 16 Old 11-13-2006, 01:29 PM
GreenDean
GreenDean's Avatar
If you are getting a constant 5 volts threw the center pin AND/OR you get no reading across the two outters, you have a bad ground.
GreenDean is offline
post #5 of 16 Old 09-04-2010, 01:23 PM
maro35089
i did this test and the center pin is runnig -1 to -2v does that mean its bad. that is with the engine running. with the engine off and in the on position its reading 4.3v bad sensor??
maro35089 is offline
post #6 of 16 Old 09-04-2010, 03:58 PM
rm2001wj
rm2001wj's Avatar
One of the 3 pins is a ground and the other 2 have a positive voltage that is measured with respect to ground. Do the measurements again, but this time connect the negative probe of the voltmeter to some point (metal) on the engine or body, and then measure the voltage, with the positive probe, at each of the 3 pins separately. One of the outer pins should have zero volts (that's the ground) while the other should be at about 5 volts. The center pin will have a positive voltage this time.
rm2001wj is offline
post #7 of 16 Old 07-05-2011, 09:06 PM
reeldagg
P0108 - MAP Sensor - Jeep
I've had the same issue(s) with my 99 Jeep Grand Cherokee 4.7L. I had the wiring redone for the MAP sensor, the problem returned, replaced the sensor - still no joy. I suspect my problems are/were not related to the sensor, but the catalytic converter being blocked - so I've just replaced the cat. So far I have driven about 500km without any of the issues returning ( will let you know if they do). I reckon if I get to about 1500km driving without this P0108 happening I can say the problem is solved.
This is what I was experiencing
- Stalls while driving (just stopping dead)
- Slight surging at idle between 500rpm and 1000rpm
- Sudden shudder on open road while driving at 100kmph.
- Regular P0108.
What made me think it was a blocked cat ?
- Stalling is one of the symptoms
- I'd fixed the MAP sensor and I didn't want to believe it was the PCM.
- Surging
- The car has done 200,000 km and cats do wear out over time apparently.
- When starting up cold you could hear a bit of a hiss from the exhaust that wasn't there when the car was warm, cats apparently warm up and expand to allow the gas to pass through. If you cat is getting blocked you might notice this sort of noise.
I realise the original post is an old one - but hopefully my experience can help someone else.
reeldagg is offline
post #8 of 16 Old 07-08-2011, 05:45 AM
reeldagg
problem returned
reeldagg is offline
post #9 of 16 Old 10-12-2011, 10:56 PM
badnunik
I'm having the same issue, has anyone solved this problem yet?
badnunik is offline
post #10 of 16 Old 10-13-2011, 04:46 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Hiss=exhaust or manifold leak?
coralman is offline
post #11 of 16 Old 11-18-2013, 05:44 PM
Blakes10
1999 Grand Cherokee
I just found this site, but have experienced the same Diagnostic Code. What concerns me is driving the car. On recent occasions, but at speeds of less than 20 MPH, partial electrical failure has occurred, causing loss of power steering and power boost on the brakes, along with misc items on the dash. The engine continues to run.
Is there a connection, you think, between the electrical failure and the P0108 Code? Thanks. Bill B
Blakes10 is offline
post #12 of 16 Old 01-06-2015, 02:01 AM
tylersjeep
1994 ZJ
Map sensor and cat
I need help I keeping getting error code 24 map sensor I just replaced that sensor not that long ago I am getting a really rough idle and rotten egg smell and stalling it smells awful and sound horrible massive stalling. my friend that owns a shop own owns 2 auto shop said its the cat I have the organial cat in there from 1994. so I just bought a a flowmaster cat direct fit am i on the right track here? the car runs in 20F weather fine but when it gets warm it has a lot of problems.
tylersjeep is offline
post #13 of 16 Old 01-06-2015, 03:09 PM
tylersjeep
1994 ZJ
maybe I should make a new profile cause no one ever respond to me on here I call this forum www.JEEPNOHELPFORUM.com
post #14 of 16 Old 01-06-2015, 04:26 PM
kg6mov
Hears the voices
kg6mov's Avatar
Well here's a few hints.
Don't dig up dead threads from 2 years ago, especially when they were originally for a WJ.
Did you do the MAP sensor test in the beginning of this thread?
kg6mov is offline
post #15 of 16 Old 01-07-2015, 09:25 AM
tylersjeep
1994 ZJ
Car works fine when cold but dose not work when warm out I'm pretty sure its my cat I'm going to replace it anyways its 23 years old I already put a super 44 now I'm going put a a flowmaster cat on one to compele the process I have been getting rotten egg smell for awhile
high voltage o2 sensor/bad coolant sensor Jh24k WK Grand Cherokee & XK Commander Forum 1 07-19-2013 10:22 AM
P0108 MAP Sensor '01 WJ skisprinkle686 WJ Grand Cherokee Forum 3 06-13-2010 10:50 PM
1999 4.7 p0108 with defrost sabercat ZJ Grand Cherokee Forum 9 10-22-2009 06:14 PM
High voltage after ECU switch PoorMan73 ZJ Grand Cherokee Forum 0 08-26-2009 09:20 PM
Voltage too high? aaron7 ZJ Grand Cherokee Forum 12 02-04-2009 09:46 PM
