Manual way to close sunroof? - JeepForum.com
post #1 of 19 Old 05-15-2005, 09:10 PM Thread Starter
osarte
Need help on stuck-open sunroof
The power sunroof in my 1997 JGC 5.9 LTD is stuck open. Is this something I could fix myself or do I need to take to a Jeep dealer?
Are there diagrams or instruction manuals available (maybe in PDF format) that I could download to repair the problem?
osarte is offline
post #2 of 19 Old 05-15-2005, 09:41 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I have to ask......because unless you swapped in the 5.9, Jeep didn't make any 5.9s in 97. However, there are lots of 98s.
1. Check fuses,
2. Check actuators.
3. Check for obstructions on the tracks.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 19 Old 05-16-2005, 05:54 AM Thread Starter
osarte
97 JGC sunroof stuck in vent up posn
Two corrections on my original message:
1. The motor is 5.2 and not 5.9 V8.
2. Sunroof is stuck in vent and not open position.
Yes, I've checked the tracks, fuses and circuit breakers. The sunroof breaker is actually shared with the intermittent wiper switch which works well.
Are actuators the same as relays? There's a clicking sound when the sunroof switch is pushed in the close-vent position, but not in the other direction. The sound appears to be coming from an area close to the switch. However, I can't remove or bring down the switch pod even after removing the single screw that holds it in place.
Thanks.
osarte
osarte is offline
post #4 of 19 Old 05-16-2005, 06:22 AM
RAZZMANIAC
RAZZMANIAC's Avatar
I have the same problem alot. . .it gets stuck. . . you have to carefully pry open the switch box. . . ive just played with the wires in there and stuff and its seemed to work. . .
1997 Grand Cherokee 5.2L Tsi
RAZZMANIAC is offline
post #5 of 19 Old 05-16-2005, 07:29 AM
Fryloc
Thanks.
osarte
I have that same problem, sounds like a gear or something is stripped. I'd hate to have to drop the headliner just to get to it, but since it is this >< close to being fully closed I'm not to worried about it. I'll probably get to it when it warms up more.
Fryloc is offline
post #6 of 19 Old 12-05-2005, 05:51 PM
snukel
Hi,
I have a 98 Jeep Grand Cherokee Limited with a factory installed sunroof/moonroof. Something is wrong with the motor (I think) and the moonroof will open but it won't close. Does anyone know of a way to manually close the roof? Thanks for any help!
snukel is offline
post #7 of 19 Old 12-05-2005, 06:14 PM
Meerkat
Like the power windows, about the only way to manually close the sunroof is to disconnect the motor and force it with your hands. A pretty tough job any way you look at it.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #8 of 19 Old 12-05-2005, 06:29 PM
snukel
Ug
Thanks for your reply. Since I'm not a very strong person, I think manually forcing it would be pretty much out of the question. Would you have any idea how much a shop would charge me to fix something like this? Otherwise, I may have to go begging to some of my stronger friends.
snukel is offline
post #9 of 19 Old 12-05-2005, 06:54 PM
snukel
Any other suggestions?
Were you able to get your sunroof to close? I am having the same problem and was wondering if there were any additional suggestions on getting it to close. I was hoping there was, at the very least, a manual way to close the sunroof but on a recent post I created, it was suggested that the only way to close it would be to manually push it back. Thanks for any help before the rain starts this week!
snukel is offline
post #10 of 19 Old 12-05-2005, 07:26 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Not cheap. I'd go and look for some strong folks. I know five folks with sunroofs, only one isn't more than 5 years old and that's the one that works, the rest don't.
I don't want a sunroof. If I want sun on my head, I'll stick my head out the window, or chop the roof off.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #11 of 19 Old 12-05-2005, 07:38 PM
97JGCLIMITED
Sunroofs aren't cheap to fix. My sunroof would vent but wouldn't slide back and forth. I took mine to the dealer and got them to fix it. I think the total repair bill was over $800.
I was able to hold the switch in the direction I wanted the sunroof to go and manually push it open or closed though. It didn't take that much effort I believe. On the inside, there is a type of lip to grap a hold of while you push it so that makes it a little easier.
97JGCLIMITED is offline
post #12 of 19 Old 12-05-2005, 08:01 PM
Bob D.
If you are ok with just leaving it closed...go to a glass shop, they should have those vacuum rubber suction cup things for moving and holding large sheets of glass. If there is enough room to attach one or two of those you can push it shut while pressing the close button.
If the window moves at all you could also try using silicone spray lube and spray the side channels and weather stripping that faces the glass while moving the glass back and forth until its loose enough to close on its own - the dried out weather stripping causes a lot of drag.
I had an '89 Cherokee with a drivers side window that wouldn't close unless I pulled it up by hand and pushed the close button at the same time.
I sprayed the heck out of side channels and weather stripping and worked the window, after awhile it moved up and down faster than the rest.
Bob D. is offline
post #13 of 19 Old 12-06-2005, 02:41 PM
snukel
Looking for a replacement actuator to fix sunroof
Hi and thanks for all of your replies.
We took out the headliner and looked at the motor, etc. and we have narrowed it down to the actuator needs to be replaced.
The motor works.
The switch works.
The actuator clicks.
But when we flipped the wires then the open side works to close.
I called the Jeep Parts dealer and they told me they don't sell actuators and that I would probably need to buy a whole new motor to get the actuator. That's about $700, I don't want to spend.
Anyone know where I could get just a new actuator? It's a pretty easy fix from there.
Thanks!
snukel is offline
post #14 of 19 Old 12-06-2005, 03:10 PM
wmm_16
Are you sure you don't mean relay?
1996 Jeep Grand Cherokee Limited
4.0 I6 2WD
Clear corners
K&N Filter
Alpine head unit
Firestone Destination LE's
wmm_16 is offline
post #15 of 19 Old 12-07-2005, 02:05 PM
snukel
Okay, the relay. Anyone know where to get a relay?
snukel is offline
07 GC Sunroof Won't Close All the Way! sost1sg WK Grand Cherokee & XK Commander Forum 22 05-15-2016 02:20 PM
ZJ Sunroof won't close! Help!? Nurburgringer ZJ Grand Cherokee Forum 9 11-06-2015 04:40 PM
Sunroof Help! Opened but won't close... wportervt WJ Grand Cherokee Forum 6 10-31-2013 04:05 AM
Sunroof won't close Greedi ZJ Grand Cherokee Forum 0 08-28-2006 06:38 AM
sunroof, automatic or manual? b0nusmoshpit2 ZJ Grand Cherokee Forum 13 04-06-2006 05:38 PM
