Got a 99 WJ here with the manual controls, the blowers does nothing on any position, No power at the resistor guessing I have a bad blower switch ?
Need to pull the control out tomorrow and check for power at that switch. Under hood fuse looks good and when the HVAC selector is turned a relay in the control clicks on and the vents change position.
Common problem ? Pattern Failure ? Probably not the electronic HVAC's but surely its happened to other. Didnt see many reference to manual control hvac problems, or they were the resistor.
Thanks for any help folks.
