Major repair, advice needed - JeepForum.com
post #1 of 17 Old 03-08-2006, 10:25 AM Thread Starter
yen
My '99 Grand Cherokee Lmtd is sitting in Aamco awaiting my decision. It was still running but I heard some heavy clunking noise at high speed on the freeway. They said the transfer case is busted and needed to be rebuilt/replaced ($1500-$2200) and the rear diff is also damaged and needed to be replaced ($1600-$2400). The Jeep is completely stock.
So, what should I do? Are the prices reasonable? (I'm in Orange County, CA by the way). Should I even do it considering the repair cost is a significant fraction of the price? Argh!
Trade the thing in for a new one?
Time to upgrade with a new transfer case and locking diff?
yen is offline
post #2 of 17 Old 03-08-2006, 10:26 AM
Myrtle Beach
how many miles are on your Jeep?
---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG---
Myrtle Beach is offline
post #3 of 17 Old 03-08-2006, 10:28 AM
Varkyl
No where near stock
Varkyl's Avatar
option D: get a second opinion.
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline
post #4 of 17 Old 03-08-2006, 10:42 AM
dpierson
Hello neighbor
I would get another opinion. But even if the TC needs replacement it can be done yourself with some help for a lot less. What do they say is wrong with the rear diff? For that price I think you could do a significant upgrade to the rear axle.
Also help us out and let us know what engine and TC you have.
Dan
Traded 8/9/07
Black 94 ZJ Laredo 4.0L 42RE/NP231 Command Trac
Sylvania Silverstars, Alpine CD Head Unit, Pioneer 3-Ways in the Doors, Blacked Out Grill, Kolak Exhaust, Clear Corners, Bilstein Shocks, Gas Tank Skid, Rear Hitch, Hitch Wiring, TC Skid, Hellwig RSB, Military FSB, Brembo Front Rotors, OME SS, B&M Supercooler, RE Tie Rod, Limited Power Leather Seats, 30x9.5 Toyo Open Country ATs, Optima Red Top
Next Mods: Upgrade Battery Cables, Sliders, Black Steelies, 3" Lift, Rear Locker, Bumper, HO Alternator, Winch, Driving Lights
dpierson is offline
post #5 of 17 Old 03-08-2006, 10:42 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Both sounds way high. Throw in an Aussie locker and a new TC. If you don't do it yourself take it to a 4wd shop instead of a regular mechanics shop.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #6 of 17 Old 03-08-2006, 10:44 AM
Airborne Lee
Airborne Lee's Avatar
Not sure which dif you have but there are several aftermarket dif's installed for much less including lockers.
My trainy repair at a $tealership was $2400 so not too suprising.
Go with option D
please buy this NEW IN BOX:
3 Previous Jeeps - 01 WJ Ltd, QD & UC - 01 WJ Ltd, QT II - 98 XJ Ltd
Airborne Lee is offline
post #7 of 17 Old 03-08-2006, 10:50 AM
Blast Chamber
Without knowing the miles and condition of your Jeep it's somewhat hard to say, but if it were mine and still drivable I'd go trade it in. Currently new Jeeps have the 0% financing for 60 months, and it's a buyer's market for used Jeeps. I can't see spending $4k plus on repairs for something with a lot of miles.
2004 Limited 2wd 4.7L
Blast Chamber is offline
post #8 of 17 Old 03-08-2006, 11:02 AM Thread Starter
yen
My Jeep has 91K on it. I don't have any mechanical experience with cars so diy is pretty much out of the question for me. It'll just make it worse. If you are local to this area (OC) can you recommend a good 4WD shop?
What engine and TC do I have? Uhmm.... it's a 4.7L V8. Don't have a clue about the TC. What ever the stock TC is for this model ('99 GC lmtd, w/ a towing package).
They said the rear diff made a lot of noise and is loose. That one they will need to open up (for a fee of course) and give me a better estimate.
yen is offline
post #9 of 17 Old 03-08-2006, 11:21 AM
Myrtle Beach
the rear ends on the Jeep tend to go out around the mileage you have. I had mine redone recently. My buddy who works at a Jeep dealership did all new bearings, parts and labor for around $450. He said they see these things all the time. he tends to think they come a little to "Tight" from the factory and wear out prematurely. I would be hesitant to let Aamco do a rear end. You really need to find someone that does these things all the time and is familar with the correct pre-load and clearences.
post #10 of 17 Old 03-08-2006, 01:06 PM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
I wonder what caused this, I hope mine does not go bad...
WALTER
walter_da_jpr is offline
post #11 of 17 Old 03-08-2006, 01:11 PM
Gun1t28
better watch out my dads 1995 ford F150 had an axle problem and took it to a mechanic. They said that it needs an entire new axle. My dads friend took a look at it and said it just needed new seals and bearings. So if you have a friend that knows about axles then have them check it out before you do anything. Also if money is an issue then go junkyard shopping.
01 WJ 4.0L
Quagmire: Fat chicks need love too...they just have to PAY!
Gun1t28 is offline
post #12 of 17 Old 03-08-2006, 05:37 PM
Airborne Lee
Silly me...
Can't he just get a used TC and a locker for the dif. I would think he could get away with only 2k? What was the jeep graveyard/parts place from a week or so ago?
post #13 of 17 Old 03-09-2006, 09:32 AM Thread Starter
yen
2k? ohh I like.....
yen is offline
post #14 of 17 Old 03-09-2006, 09:56 AM
dpierson
I did some searching and a new TC is about $800 depending on what model you have. If you can do any wrenching you could do it yourself and that alone would save you at least $500 from the price Ammco quoted you. Then you could probably buy a complete rear axle and install it yourself for a lot less than what they want.
Dan
Traded 8/9/07
dpierson is offline
post #15 of 17 Old 03-09-2006, 02:44 PM
AZMark
Wouldn't it be uncommon for both to fail at the same time? Maybe only one transfer case or rear-end is broken? Anyway I'm in AZ and always use small shops that let me get my own parts and charge around $60 per hour for labor. I had a really noisy rear-end in one of my Zjs recently and it only cost me a total of around $275 to get the bearings replaced that had come apart. Look at Ebay auction # 8044004295 for a 242 transfer case from a 2004 WJ. Only $300 with no reserve and no one even bid on it (maybe still avail.?). You could rent a car for quite a while if you had to in comparison to the super high rates you where quoted.
AZMark is offline
Help needed with advice pls jeremy18 ZJ Grand Cherokee Forum 9 07-27-2008 02:09 PM
Looking at a 5.9L...Some Advice Needed Grbeast001 ZJ Grand Cherokee Forum 8 11-20-2007 02:24 PM
Major Wiring Issues-help needed!!! 85Chief ZJ Grand Cherokee Forum 2 10-22-2007 02:21 PM
Advice needed blackhawk24701 ZJ Grand Cherokee Forum 2 03-20-2007 12:14 AM
Major transmission leak help needed. zj+3 ZJ Grand Cherokee Forum 5 06-15-2004 11:56 AM
