M1 inlet on it's own: noticable difference? - JeepForum.com
post #1 of 12 Old 09-02-2009, 04:10 AM Thread Starter
vanderputtens
I should be receiving my M1 inlet soon and in anticipation of fitting it I was wondering if I will notice any difference at all on my 5.9?
If so what will I notice?
vanderputtens is offline
post #2 of 12 Old 09-02-2009, 11:45 AM
driabyor
driabyor's Avatar
1994 ZJ
fuel mileage probably not .... power & torque depends on the specs.....
biggest difference will be in your walllet....thinner
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 12 Old 09-02-2009, 01:04 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you'll get a hp increase, powerband will climb upwards a few hundred rpm so it may seem like a low end power loss. mileage may increase slightly.
ratmonkey is offline
post #4 of 12 Old 09-02-2009, 01:14 PM
tirus89
you can get a turtle to fix the low end power loss though.
tirus89 is offline
post #5 of 12 Old 09-16-2009, 02:17 AM Thread Starter
vanderputtens
Well that doesn't sound to enthusiastic...I was under the impression that the M1 was a pretty big important thing overall when modding the Jeep power-wise?
post #6 of 12 Old 09-16-2009, 04:24 AM
comptiger5000
Yes, but often mods work together, and some aren't very effective on their own, but help another mod work better.
comptiger5000 is offline
post #7 of 12 Old 09-16-2009, 11:03 AM
GrandHokie96
is the M1 the only performance mod you'll have on it?
if so, like already stated, you may not notice it as much. I had CAI, bored TB, full 3" exhaust, and tune before i did the M1 and i could instantly feel the difference. but i dont know how it would be on a stock engine.
'98 Grand Cherokee 5.9L V8
-Stock suspension, 235/75R15 BFG AT's, AR767 rims with 4" BS - Fastman 52mm Throttle Body, K&N FIPK Gen 2, Kolak Exhaust, DMH Cutout, DT Headers, M1 Intake - 8300k 9004 Hi/Low HID's, 8000k H3 Off-Road Lamps - Rockford Fosgate P8002 and P4004 amps, 2x 12" Kicker CVR subs, Kicker SS56.2 components in Q-Logic kickpods, Front and rear Punch components, another set of components in the sound bar, 3600 watts total
GrandHokie96 is offline
post #8 of 12 Old 09-16-2009, 12:17 PM
tirus89
The M1 Allows more air flow, so if your using a stock TB, your only getting in so much air, thus a bottle neck. Yes there will be some power gained, but the M1 is to be coupled with a TB and free flowing intake of your choice. Even then if you want your low-end power back a turtle is going to be needed for the M1. I'd rather suggest a stock intake thats ported or a "ported kegger".
tirus89 is offline
post #9 of 12 Old 09-16-2009, 12:26 PM Thread Starter
vanderputtens
Well I planned other mods as well such as a larger TB and headers coupled to a Kolak exhaust.
it just so happened that the M1's were in short supply so I thought I get one before it would be hard to get so to say...I do realise that mods tend to add up to eachother though!
post #10 of 12 Old 09-16-2009, 05:07 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
then buy it, it's a great piece(the hughes edelbrock airgap they modify is great too and not going anywhere soon).
post #11 of 12 Old 09-16-2009, 08:33 PM
newfieZJ
I think you'll see more of an improvement than the others have said , If your intake is stock , the probability of a leaking plenum is extremely high w/o a hughes plate . The vacumn leak alone in a power loss . M1's have a one pc design , no plate , to me , that's worth the cost right there .
Your on the right track
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #12 of 12 Old 10-05-2009, 04:13 AM Thread Starter
vanderputtens
BTW. What's a turtle???
muffler inlet and outlet diameters? on 05 WK? and inlet and outlet placement? PJNovinskee27 WK Grand Cherokee & XK Commander Forum 0 05-12-2009 07:01 PM
CCV HELP! Where's the manifold inlet???? TowMaster ZJ Grand Cherokee Forum 13 04-03-2009 08:37 PM
93 ZJ 5.2 Cat inlet size???? CarbonCaster ZJ Grand Cherokee Forum 5 05-17-2008 12:04 AM
Do the k&n 57 serios intake give noticable gains? jeepboy1618 WK Grand Cherokee & XK Commander Forum 21 01-14-2008 05:11 PM
Removing air inlet fitting rwild ZJ Grand Cherokee Forum 5 02-26-2006 09:55 AM
