M1 inlet on it's own: noticable difference? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > M1 inlet on it's own: noticable difference?
Last Day to take advantage of 5% off August PromoThe Cure for your Tie Rod Roll!The Original 3/8" Ruffstuff Diff Cover!
Unread 09-02-2009, 04:10 AM   #1
vanderputtens
I should be receiving my M1 inlet soon and in anticipation of fitting it I was wondering if I will notice any difference at all on my 5.9?
If so what will I notice?
vanderputtens is offline   Reply With Quote Quick reply to this message
Unread 09-02-2009, 11:45 AM   #2
driabyor
1994 ZJ
fuel mileage probably not .... power & torque depends on the specs.....
biggest difference will be in your walllet....thinner
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline   Reply With Quote Quick reply to this message
Unread 09-02-2009, 01:04 PM   #3
ratmonkey
R.I.P.
ratmonkey's Avatar
you'll get a hp increase, powerband will climb upwards a few hundred rpm so it may seem like a low end power loss. mileage may increase slightly.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 09-02-2009, 01:14 PM   #4
tirus89
you can get a turtle to fix the low end power loss though.
tirus89 is offline   Reply With Quote Quick reply to this message
Unread 09-16-2009, 02:17 AM   #5
vanderputtens
Well that doesn't sound to enthusiastic...I was under the impression that the M1 was a pretty big important thing overall when modding the Jeep power-wise?
Unread 09-16-2009, 04:24 AM   #6
comptiger5000
Yes, but often mods work together, and some aren't very effective on their own, but help another mod work better.
comptiger5000 is offline   Reply With Quote Quick reply to this message
Unread 09-16-2009, 11:03 AM   #7
GrandHokie96
is the M1 the only performance mod you'll have on it?
if so, like already stated, you may not notice it as much. I had CAI, bored TB, full 3" exhaust, and tune before i did the M1 and i could instantly feel the difference. but i dont know how it would be on a stock engine.
'98 Grand Cherokee 5.9L V8
-Stock suspension, 235/75R15 BFG AT's, AR767 rims with 4" BS - Fastman 52mm Throttle Body, K&N FIPK Gen 2, Kolak Exhaust, DMH Cutout, DT Headers, M1 Intake - 8300k 9004 Hi/Low HID's, 8000k H3 Off-Road Lamps - Rockford Fosgate P8002 and P4004 amps, 2x 12" Kicker CVR subs, Kicker SS56.2 components in Q-Logic kickpods, Front and rear Punch components, another set of components in the sound bar, 3600 watts total
GrandHokie96 is offline   Reply With Quote Quick reply to this message
Unread 09-16-2009, 12:17 PM   #8
tirus89
The M1 Allows more air flow, so if your using a stock TB, your only getting in so much air, thus a bottle neck. Yes there will be some power gained, but the M1 is to be coupled with a TB and free flowing intake of your choice. Even then if you want your low-end power back a turtle is going to be needed for the M1. I'd rather suggest a stock intake thats ported or a "ported kegger".
Unread 09-16-2009, 12:26 PM   #9
vanderputtens
Well I planned other mods as well such as a larger TB and headers coupled to a Kolak exhaust.
it just so happened that the M1's were in short supply so I thought I get one before it would be hard to get so to say...I do realise that mods tend to add up to eachother though!
Unread 09-16-2009, 05:07 PM   #10
ratmonkey
R.I.P.
ratmonkey's Avatar
then buy it, it's a great piece(the hughes edelbrock airgap they modify is great too and not going anywhere soon).
Unread 09-16-2009, 08:33 PM   #11
newfieZJ
I think you'll see more of an improvement than the others have said , If your intake is stock , the probability of a leaking plenum is extremely high w/o a hughes plate . The vacumn leak alone in a power loss . M1's have a one pc design , no plate , to me , that's worth the cost right there .
Your on the right track
newfieZJ is offline   Reply With Quote Quick reply to this message
Unread 10-05-2009, 04:13 AM   #12
vanderputtens
BTW. What's a turtle???
