Lunch Box Slack??? - JeepForum.com
post #1 of 10 Old 04-13-2009, 02:03 AM Thread Starter
johnnycrash
Lunch Box Slack???
Anyone here running Lunchboxes front and rear in stock axles?
I'm Running a loc-right in my 30, and a No-slip in my 35 out rear, and when i go from drive to reverse, or vice versa i have a lot of slack, it makes a loud clack noise.
It was first noticable after i installed the rear one, as it went in 6 months or so before i locked the front. Anyone else have this? should i worry about damage, or is it just an annoyance?
Thanks.
johnnycrash is offline
post #2 of 10 Old 04-13-2009, 02:56 AM
sandman
sure its not a u-joint on your ds?
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 10 Old 04-13-2009, 03:00 AM Thread Starter
johnnycrash
I was pokin around under there and didnt notice any play in the DS, but ill check again. I have vibes since i lifted, but hasnt made the noise anyworse, i dropped the t-case last night, helped with the vibes alot, and with the torque steer i was gettin. ill double check the the U-joints..
post #4 of 10 Old 04-13-2009, 10:48 AM
AgitatedPancake
if your getting torque steer I bet some of your control arm bushings are shot.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #5 of 10 Old 04-13-2009, 10:53 AM
rugermack
If everything else feels good, check the transfer case chain.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #6 of 10 Old 04-13-2009, 01:39 PM Thread Starter
johnnycrash
Im pretty sure all my ca bushings are finished, the torque steer showed up after the no slip went in the rear, step on the gas and she pushes to the drivers side, let off it and it goes to the pass side. Im ordering all adjustable ca's, just have to get the money together. I'm also waiting as i have to replace my front diff since its bent on the drivers side and my tire has a serious camber issue. so when ill install the new d30 and the arms all at once. How much is a t-case chain? or where would i order one from?
post #7 of 10 Old 04-13-2009, 02:39 PM Thread Starter
johnnycrash
ok so it looks(well sounds) like its the tcase chain, if i twist the ds i hear the chain tapping the casing.
guess ill have to pull it apart.
post #8 of 10 Old 04-13-2009, 07:34 PM
StrokedWJ
StrokedWJ's Avatar
That sounds like pretty standard driving characteristics of a lunchbox locker to me. The increased slack is due to the extra clearance around the carrier pin. In the stock diff the pin is snug in the carrier. With the locker there is just a tiny bit of play back and forth. I bet you've also noticed that if you park on a hill and don't use the e-brake that it rolls a foot or so further than it used to...It was scary the first time I felt it!
The torque steer you're talking about sounds normal too. Worn bushings could definitely make it worse.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #9 of 10 Old 04-13-2009, 08:11 PM
rustynail
I had a lock right in a samurai and in neutral I could twist the drive shaft a lot. If the sound started when you did the rear then I would be concerned about the sound because you did not have a lunchbox locker then. Make sure your tc is in neutral when you check your drive shafts.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #10 of 10 Old 04-14-2009, 04:28 AM Thread Starter
johnnycrash
ah well it wasnt in neutral, the tranny was but not the tcase.... yea she rolls when parked, about a foot. .. now you would or wouldnt be concerned about the sound, sorry didnt quite follow that.
"slack" when turning joshuatchandler ZJ Grand Cherokee Forum 14 01-29-2010 07:45 PM
Where do I take the slack out of parking brake? CruiserClass ZJ Grand Cherokee Forum 5 04-27-2007 10:51 PM
