lug nut torque - JeepForum.com
post #1 of 16 Old 04-27-2013, 01:21 PM Thread Starter
coralman
USER OF PARTS CATALOGS
coralman's Avatar
lug nut torque
Please, as above, thanks!
Originally Posted by HighLonesome
coralman is offline
post #2 of 16 Old 04-27-2013, 01:22 PM
WhiteOut
WhiteOut's Avatar
~100' lbs
WhiteOut is offline
post #3 of 16 Old 04-27-2013, 01:23 PM Thread Starter
coralman
coralman's Avatar
Thanks WhiteOut!
coralman is offline
post #4 of 16 Old 04-27-2013, 05:18 PM
KoreaZJ
1994 ZJ
No lube on the studs.
KoreaZJ is offline
post #5 of 16 Old 04-27-2013, 07:17 PM
ZeeJay1997
I torque mine to 110, run it and torque again while hot.
I used a very sparing amount of anti seize compound. Once you put it on there and wipe all excess off, you never have to do it again... or at least i haven't.
Been running fifteen years and nuts come off with the lug wrench under the seat. Haven't lost a wheel yet... and the brake rotors don't warp.
ZeeJay1997 is offline
post #6 of 16 Old 04-27-2013, 07:40 PM
WhiteOut
WhiteOut's Avatar
Don't lube them, you're applying a huge amount more tension to that stud than torquing dry.
WhiteOut is offline
post #7 of 16 Old 04-27-2013, 07:57 PM
Y0ungGunZJ
At work we do 110.
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline
post #8 of 16 Old 04-27-2013, 11:02 PM Thread Starter
coralman
coralman's Avatar
Thanks for all the replies, I need to figure out why the rotor/pads are getting hot.
coralman is offline
post #9 of 16 Old 04-28-2013, 07:15 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
80ftlbs with anti seize.
ratmonkey is offline
post #10 of 16 Old 04-28-2013, 07:55 AM
AmishFury
this is a jeep not a toyota
AmishFury is offline
post #11 of 16 Old 04-28-2013, 07:56 AM
tucsonzj
ratmonkey, you need to just write a book on anything everything zj. I'd buy it.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #12 of 16 Old 04-28-2013, 08:09 AM
Maine1994ZJ
I work at a busy tire shop. We torque all wheels to factory specs.
In a nut shell, if it's a domestic make(GM, Ford, Mopar) it is 100ft/lbs.
If it's an import, it's 80ft/lbs
There are a few exceptions, like Newer Mopar trucks & GM trucks & new Tundras that take 120ft/lbs
There are a few older Volvos that take 65ft/lbs.
All Jeeps: 100ft/lbs. NOTHING on threads. PERIOD!
If it was supposed to have never seize or grease on it they would put it on from the factory, which they don't do.
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #13 of 16 Old 04-28-2013, 08:56 AM
AmishFury
there are some trucks that spec 140+ft/lbs
usually the 3/4ton and higher but even some 1/2ton
i personally hate when one comes in... almost always at least one lug nut that wants to be a pain in the *** and we have even had 2 sockets crack on a couple GMCs
post #14 of 16 Old 04-28-2013, 09:52 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Anti seize reduces required fastener torque by roughly 25%.
post #15 of 16 Old 04-28-2013, 05:10 PM
spidermonkey
Yes^ and if you live in the salt belt, you better ant-seize anything you plan to be able to remove ever again.
98ZJ, 4.0,242, 8.8 Detroit, hp30, 3.5" lift, IRO LA's 4.56's, 33" Firestone MT's, custom rear bumper, ARB front, Engo E9000, factory skids
My driveway build here:
speedo reading x spd gear tooth count/gps speed = new spd gear for dead on accuracy
North Shore Wheelers
spidermonkey is offline
