-   -   lug nut torque (http://www.jeepforum.com/forum/f13/lug-nut-torque-1515336/)
coralman 04-27-2013 01:21 PM
lug nut torque
Please, as above, thanks!
WhiteOut 04-27-2013 01:22 PM
~100' lbs
coralman 04-27-2013 01:23 PM
Thanks WhiteOut!
KoreaZJ 04-27-2013 05:18 PM
No lube on the studs.
ZeeJay1997 04-27-2013 07:17 PM
I torque mine to 110, run it and torque again while hot.
I used a very sparing amount of anti seize compound. Once you put it on there and wipe all excess off, you never have to do it again... or at least i haven't.
Been running fifteen years and nuts come off with the lug wrench under the seat. Haven't lost a wheel yet... and the brake rotors don't warp.
WhiteOut 04-27-2013 07:40 PM
Don't lube them, you're applying a huge amount more tension to that stud than torquing dry.
Y0ungGunZJ 04-27-2013 07:57 PM
At work we do 110.
coralman 04-27-2013 11:02 PM
Thanks for all the replies, I need to figure out why the rotor/pads are getting hot.
ratmonkey 04-28-2013 07:15 AM
80ftlbs with anti seize.
AmishFury 04-28-2013 07:55 AM
this is a jeep not a toyota
tucsonzj 04-28-2013 07:56 AM
ratmonkey, you need to just write a book on anything everything zj. I'd buy it.
Maine1994ZJ 04-28-2013 08:09 AM
I work at a busy tire shop. We torque all wheels to factory specs.
In a nut shell, if it's a domestic make(GM, Ford, Mopar) it is 100ft/lbs.
If it's an import, it's 80ft/lbs
There are a few exceptions, like Newer Mopar trucks & GM trucks & new Tundras that take 120ft/lbs
There are a few older Volvos that take 65ft/lbs.
All Jeeps: 100ft/lbs. NOTHING on threads. PERIOD!
If it was supposed to have never seize or grease on it they would put it on from the factory, which they don't do.
AmishFury 04-28-2013 08:56 AM
there are some trucks that spec 140+ft/lbs
usually the 3/4ton and higher but even some 1/2ton
i personally hate when one comes in... almost always at least one lug nut that wants to be a pain in the *** and we have even had 2 sockets crack on a couple GMCs
ratmonkey 04-28-2013 09:52 AM
Anti seize reduces required fastener torque by roughly 25%.
spidermonkey 04-28-2013 05:10 PM
Yes^ and if you live in the salt belt, you better ant-seize anything you plan to be able to remove ever again.
The time now is 05:20 AM.
