Lucasoil Tranny Fix - Drain or No Drain? - JeepForum.com
post #1 of 5 Old 12-02-2008, 01:12 PM Thread Starter
swataz
I have read on numerous threads about adding Lucasoil's Transmission Fix to their transmissions for one reason or another, and that it is pretty much a standard practice to remove about a quart (or sometimes 24 ounces) to allow for the addition of the Lucasoil product.
However, when I look at their website, one of the "Key Benefits" they list is the ability to add product without draining any transmission fluid (check bullet 3):
http://www.lucasoil.com/products/dis...tid=9&loc=show
Curious if any of you have chosen the approach of no drainage. Either way, I have a hand pump at the ready, but it's always good to hear real-world experiences from folks.
Hope you can help!
swataz is offline
post #2 of 5 Old 12-02-2008, 02:39 PM
mtcox
I just added one quart to my tranny after siphoning off about the same amount. I'm not seeing any difference in performance. It still slips and puts the tranny into limp mode. I have a second quart that I may or may not add. I don't know that it's going to help any more. The web site does say that more than one quart may be necessary. My tranny may be too far gone. Be sure to warm up the Lucas Oil. It's thick and takes some time to pour down the dip stick tube. I think if you warm it up in a hot water bath it may make it flow a bit easier. Good luck.
2001 Jeep Grand Cherokee Limited 4.7L
mtcox is offline
post #3 of 5 Old 12-02-2008, 02:42 PM Thread Starter
swataz
Thanks for the tip and well, sorry to hear about your tranny's condition, mtcox.
What kind of issues was the Jeep exhibiting before you added the Lucas? Did it have the ever-popular 2nd to 3rd when cold slip? Was it throwing any codes?
swataz is offline
post #4 of 5 Old 12-02-2008, 04:41 PM
mtcox
It continues to throw numerous codes. Read about it at:
www.jeepforum.com/forum/showthread.php?t=586656
It is slipping on cold starts. It behaves like a normal tranny when it's warmed up but it continues to put itself in limp mode before I can get 2-3 miles down the road. I simply stop and erase the codes with a scanner. It's a pain but it's saving me from spending money on the replacement for the time being. I've got an email into Lucas about what to do. I'd rather not add another $13 quart of oil if it's not going to help.
The slipping is immediate when placed in gear. It takes 10-15 seconds when I select drive or reverse for the Jeep to engage and then it behaves like a manual transmission when you don't let the clutch all of the way out. High RPM's and little movement. It's at this stage it begins to throw codes and the check engine light illuminates. I've found used transmissions for $600 - $1,200. It's a project for after Christmas. The Haynes manual details the removal and replacement but I'm happy to have any input on swapping out these tranny's.
mtcox is offline
post #5 of 5 Old 12-02-2008, 06:27 PM Thread Starter
swataz
That sucks...I must admit my transmission is not that bad - YET. But I am sure in time I am looking at a rebuild. I know true Jeep lovers will kill me for saying this, but I just need it to last another year or so, and if the Lucas is a quick fix, and it works for now, so be it.
Good luck with your issues.
swataz is offline
Radiator Drain Plug? Coolant wont drain epfriis ZJ Grand Cherokee Forum 6 06-18-2015 12:18 PM
AC drain Thelt ZJ Grand Cherokee Forum 0 12-10-2009 09:19 AM
AW4 Tranny drain bolt? replace fluid ZJcrawler45 ZJ Grand Cherokee Forum 7 09-23-2007 11:52 AM
anyone installed a drain plug on the tranny pan of a WJ? mailforjon ZJ Grand Cherokee Forum 24 11-30-2006 01:27 PM
93 AC Drain MaineZJ ZJ Grand Cherokee Forum 2 08-19-2003 05:42 PM
