Lucas or Trans-X ? - JeepForum.com
post #1 of 11 Old 07-02-2005, 11:44 AM Thread Starter
Briandl
Lucas or Trans-X ?
I know I've been asking tons of questions as a new Jeep owner but here is another.
Trans-X or Lucas for my transmission or neither?
It's difficult because there is so much contradicting information.
I know Daimler Chrysler doesn't recommend additives. I know I've read people's opinions about Lucas but most are from people who have used it on other vehicles or had friends that did, not a lot of info from people that used it on their Jeeps. I also read at least once someone mentioning that Trans-X is better for Chrysler vehicles than Lucas is.
Extended Reading:
Basically my transmission has become more noticeable when shifting, I changed the fluid and filter and I believe that helped but with almost 100K miles on that transmission and the fact that it was 9K miles past due for the fluid change I am thinking something like Lucas would be good to add but again I've read so much that I am looking for any additional info anyone can share.
Thanks in advance!
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #2 of 11 Old 07-02-2005, 03:06 PM
Meerkat
Brian,
I don't recommend any additives or fluids other than Mopar ATF+ 4 in your transmission. If you used any fluid other than ATF+ 4 when you changed the fluid and filter, that is probably the source of your current problem.
If you did use ATF+ 4 at the last filter/fluid change, then you may have a sticking selenoid. An air test performed at any reputable transmission specialty shop will quickly verify or disprove this idea.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 11 Old 05-30-2013, 04:55 PM
thor68372rockon
1977 CJ7
Trans X Or Lucas?
Hey Guys, I'll Try To Help A Little Bit If I Can. I've Been An Auto Mechanic For 28 Years & The Way I've Done It Is If An Automatic Trans. Slips It's On Its Way Out. If You Want To Safe Guard A Good Non-Slipping Trans., Use Trans-X. I Am Not A Dealer Or Get Paid By These Guys What So Ever. The Dealer Will Still Warranty The Trans. If You Use It. What I Do Is Add Half The Bottle To Trans., Drive It For 200-300 Miles (This Gives It A Chance To Clean The Valve Body & Ports In The Trans.) Then Change The Fluid & Filter & Add The Other Half Bottle To Good Fluid In Tranny. This Will Continue To Clean & Help Your Transmission. I Have Done This With Every Vehicle I Own, I've Had My 2001 Buick LeSabre Limited From The Time It Was New & Now Has 192,000 Miles On it, I Added Trans X Right Away When I Bought It, Drove It For 200 Miles, Then Changed Fluid & Filter & Added The Other Half Of The Trans X Bottle, I Have Never Had One Bit Of Trouble With That Tranny, 1975 Chevy Full-Time 4X4, I Rebuilt Trans. Added Trans X, Now Has 20,000 Miles On It, No Problems With It. I Do Use Lucas Engine Oil Stabilizer In The Engines On All My Vehicles, Lawnmowers & Snowblower. I Have Heard You Can Add Lucas Engine Oil Stabilizer To Your Transfer Case & Front & Rear Drive Axle Gear Boxes Also. I Have Not Used Lucas Tranny Additive So I Do Not Know How It Works, I Have Had Great Success With Trans X So I Will Not Change. Good Luck Guys!
thor68372rockon is offline
post #4 of 11 Old 05-30-2013, 05:12 PM
tucsonzj
Why is every word capitalized at the beginning?
No additive in ZJ trannys. ATF+4 fluid only.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #5 of 11 Old 05-30-2013, 05:41 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Gents, fluid info is in the FAQs...read them.
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 11 Old 05-30-2013, 06:27 PM
thor68372rockon
1977 CJ7
@TucsonZJ, I Just Got Used To Typing That Way & It's Haard To Break the Habit I Guess, Sorry.
post #7 of 11 Old 05-30-2013, 06:28 PM
thor68372rockon
1977 CJ7
@ TexasZJ1, Thanks For The Info. Will Check It Out.
post #8 of 11 Old 05-30-2013, 07:37 PM
BIGBADWOLF
Engineers design and build transmissions and recommend what fluids they require.....additives are designed usually by non-engineers with the hope of selling to the non-engineer driver! If you are willing to second guess a group of well educated professionals be my guest.
BIGBADWOLF is offline
post #9 of 11 Old 05-30-2013, 09:11 PM
PolkaPower
If the tranny was slipping and you needed a rebuild is the only time I would use an additive to try and squeeze some more miles out of it.
PolkaPower is offline
post #10 of 11 Old 05-30-2013, 09:44 PM
ZJfamilyfun
My 98 w/ 168k had a bad 3-4 slip when i first got it. I drained, new filter, and refilled w/ +4 and subbed 1 qt. W/ Lucas and now at 171k it has been shifting like new!
ZJfamilyfun is offline
post #11 of 11 Old 05-30-2013, 10:12 PM
AmishFury
chrysler transmissions are best if all that goes in is the correct fluid (or a backwards compatible chrysler spec fluid)
nearly every person i've known to have a chrysler transmission fail have used something else... either a universal fluid or an additive
(i say nearly because my sister killed her lebaron's transmission by driving it like it was a racecar and my mom had the transmission in her van blow a seal after a rather significant number of miles which included a fair bit of towing... and IIRC when my dad's ram charger took a manhole (was loose and his tire spun on it making it fly up) to the underside it damaged the transmission)
AmishFury is offline
Anyone use Lucas Transmission Fix in their WK? wakeskate420 WK Grand Cherokee & XK Commander Forum 1 01-23-2011 07:02 PM
Lucas Transmission fix?? frog23 WJ Grand Cherokee Forum 7 03-10-2010 10:38 AM
Lucas oil stabilizer.... KUHawkhead ZJ Grand Cherokee Forum 26 05-13-2008 12:55 PM
Lucas Oil Trans Fix Journeytojeep ZJ Grand Cherokee Forum 9 12-11-2005 07:47 PM
Lucas Transmission additive bullet ZJ Grand Cherokee Forum 8 07-01-2005 02:48 AM
