Lubricating steering and suspension ball joints - JeepForum.com
post #1 of 22 Old 06-04-2007, 05:57 PM Thread Starter
chrisstromberg
Hey guys- can someone point me in the right direction about how to lubricate the steering and suspension ball joints? Any help is appreciated.
Thanks
-Chris
chrisstromberg is offline
post #2 of 22 Old 06-04-2007, 05:59 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
get a regulare grease gun with some grease (ask the people at the auto store), shove it over every fitting you see and pump away till grease comes out of the bushing. i dont think the stock ball joints on any grand cherokee are greaseable
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #3 of 22 Old 06-04-2007, 05:59 PM
sandman
get a gun and crawl under your jeep, everywhere you see a grease fitting fill it. the grease and gun is cheap.
sandman is offline
post #4 of 22 Old 06-04-2007, 06:02 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Well, since the OP doesn't want to tell us what his rig is -- ZJs (93-98) have greasable balljoints, WJs (99-2004) do not.
Hint to OP: Fill out your profile and/or sig so we know what you have Welcome to the board.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #5 of 22 Old 06-04-2007, 06:02 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Since we have no idea which Jeep you have, if you have a WJ, the only greasable joints are the ball joints, one on top of each knuckle.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #6 of 22 Old 06-04-2007, 06:03 PM
ArloGuthroJeep
Mr. Hyde!
Hey quit smoking the crack, you have it backwards...WJ's only have greasable ball joints - nothing else is greasable.
post #7 of 22 Old 06-04-2007, 06:08 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Oopsie
I knew it was one or the other...TREs or balljoints - both are a PITA to change out anyway
That, and dubs are weird
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #8 of 22 Old 06-04-2007, 06:55 PM
02_limited
Oopsie
What's the recommend grease type/brand for the ball joints?
If you were to grab ahold of the tire rod and be able to rotate it back and forth about 1/4 - 1/2 inches and the boots looks kinda "deflated", does it mean the TREs will need to be replaced? I think it got loosen a bit when my gf hit a big pothole in the field because the steering stabilizer has a minor dent too.
02 WJ Limited 4.7 Quadradrive
02_limited is offline
post #9 of 22 Old 06-04-2007, 07:03 PM
FPKites
ZJjazzyJim
FPKites's Avatar
rotation is fine, lateral movement is bad. However, you'll have a hard time seeing lateral movement by yourself. Get under there and have a buddy that you trust turn the wheel back and forth. If the TREs try to separate at the joint, you have bad joints.
I just use the cheapy stuff at the auto parts store. Valvoline makes chassis grease, so does Coastal and every other cheapo brand. You'll be fine with that.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #10 of 22 Old 06-04-2007, 07:03 PM
Yardman Harry
O
Yardman Harry's Avatar
Use your standard grease. Nothing special. Its been so long since I refilled my grease gun I cant remember whats in it.
Also, make sure to clean the grease fittings free of the dirty gritty grease that can collect on the outside. Other wise, if you pop that grease gun on there without cleaning the fitting, you will force all of that dirt and grime into the joint, decreasing the life of the joint.
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #11 of 22 Old 06-04-2007, 07:07 PM
GRDCHRKE555
its ok if the tie rod twists a little bit. just as long as there is no lateral movement in the tie rod. mine twist too and my steering is tight.. minus my steering box being shot. stupid me stupid me
Kyle
99 XJ Classic, 4.0, AW4, 8.25 Rear
4.5" (~6'') RC lift w/ full leafs, RE 1.25" Shackles, Bilstein 5125's, IRO Custom HI-Clearance LA's,JKS quicker discos, C4x4 Front Hooks, TW's SYE/CV DS, FLO-PRO cat-back, and some 32'' x 11.50" Maxxis Bighorns
GRDCHRKE555 is offline
post #12 of 22 Old 06-04-2007, 07:13 PM
02_limited
Thanks FPKites, Yardman Harry, GRDCHRKE555
I've been searching to find out if rotation is normal or not. I have a little sloppy steering on tight curves, so I think it's the TRE. Well, I do know I need to replace the rear sway bar too. I'll check under there tommorrow and see what else I can find to burn a hole in my pocket.
post #13 of 22 Old 06-05-2007, 11:45 AM Thread Starter
chrisstromberg
Sorry I didn't mention my rig. Kinda hard to give advice if you don't know what I'm working with. '04 Grand Cherokee. So what's the consensus on what's greasable and not greasable? And the reason I asked about ball and suspension joints was because the factory manual mentioned both. Thanks for clearing that up.
Thanks for the help.
-Chris
post #14 of 22 Old 06-05-2007, 12:09 PM
mendelmax
Standard WJ has only two lube points- steering knuckle ball joint both at left and right Nothing more.
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline
post #15 of 22 Old 06-05-2007, 12:21 PM
dunno513
Insert one instruction to this.. WIPE IT OFF FIRST! Otherwise you'll pump dirt into the joint. This is one reason that auto makers stopped putting zerk fittings on everything. (Plus it's cheaper)
My grandfather used to install his own zerk fittings if a replacement didn't have one. I'm just not that inclined.
dunno513 is offline
master pro steering linkage and ball joints UnderTheWooDd ZJ Grand Cherokee Forum 1 08-12-2009 01:00 AM
ball joints arsonist_bob ZJ Grand Cherokee Forum 7 06-29-2009 08:00 PM
Ball Joints CastnBlast_91 ZJ Grand Cherokee Forum 3 05-31-2008 11:50 AM
Which ball joints dp i get? MuddyLuxury ZJ Grand Cherokee Forum 6 01-27-2008 11:11 PM
Front End Noise, Tie Rod Ends?? Steering Damper?? Ball Joints?? jimib4141 ZJ Grand Cherokee Forum 12 03-03-2007 03:44 PM
