Ls1 Zj? - JeepForum.com
post #1 of 34 Old 10-19-2007, 12:09 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Ls1 Zj?
Has anyone seen an LS1 put into a GC? How about an LS1/T56 combo?
I know Novak does a lot with putting the LS1 into wranglers, but I couldn't find anything about going into a GC. Just throwing the idea around. I want to eventually swap an LS1 into a Jeep, just trying to decide which one
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #2 of 34 Old 10-19-2007, 09:40 PM
shudog
2012 WK
As a ZJ owner who also drives an LS1 Camaro, I can tell you right now, that would be way too much power for a Grand Cherokee. The LS1 engine has decent low end grunt since it's a 5.7L V8, but it's really revver, really wakes up above 3500 rpm... a better swap would be a Chevy LT1 350 used in the 93-98 fbody cars. They still make 275 hp at the rear wheels but they are torque monsters and make the majority of the power BELOW 3500 rpm. The LT1 motors are also cheaper to find for your transplant project and just as reliable once you get past the optispark issues.
Previously owned jeeps:
'06 Grand Cherokee Limited w/4.7L V8 & QD2
'98 Grand Cherokee Limited w/5.2L V8 & Quadra Trac - sold at 230k miles
shudog is offline
post #3 of 34 Old 10-20-2007, 12:45 AM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
the 5.9 that came in the limited is a pretty beefy iron block IIRC, and puts out 245/345. The LS1 is around 350/350, and does it in a much lighter aluminum block.
Just figured it would one great power / weight ratio
-Matt
White '94 YJ Sport
UltimatE is offline
post #4 of 34 Old 10-20-2007, 01:04 AM
AgitatedPancake
I've heard a couple horror stories of guys putting healthy 350's in unibodys and twisting the body a little too much...Now i mean it cant be much harder on the body than flexing, but I've heard of a cherokee that didnt have fun for very long.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #5 of 34 Old 10-20-2007, 01:08 AM
Blade427
Subframe connectors maybe would help
1998 ZJ 318 176,xxx and still going.
Straight pipe after cat. K&N intake system. High Flow Cat. stock suspention. Slight motor tune. and to top it off some BFG 31's
Blade427 is offline
post #6 of 34 Old 10-20-2007, 01:14 PM
95ZJ
go for it for sure, that would be sweet.
rip the old motor out and drop ther LS1 in it, ask questions when u get stuck lol
95 GC limited
-lifted
-locked F+R
-33" tsl's
95ZJ is offline
post #7 of 34 Old 10-20-2007, 01:27 PM
BLACKzj52
that would be sick to see
BLACKzj52 is offline
post #8 of 34 Old 10-20-2007, 04:25 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
Did the ZJ ever come with a 5-speed from the factory? Would make for a much easier conversion if the clutch pedal was a bolt in.
-Matt
White '94 YJ Sport
UltimatE is offline
post #9 of 34 Old 10-20-2007, 05:02 PM
Blade427
There are ZJ's out there with a 5sp finding them isnt that easy though
Blade427 is offline
post #10 of 34 Old 10-20-2007, 09:29 PM
nashmd454
nashmd454's Avatar
I would be intersted in doing a swap like that....or just buy and engine that puts out over 400 ponies. There are too many options of stiffening the unibody and installing a 4 link while you are at it.
Shudog....my Supra would have eaten your camaro. I say this not to upset you...but am jealous that I no longer own it....it was a high 9 second ride. Did I ever say I miss it...ok.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #11 of 34 Old 10-20-2007, 09:51 PM
TslAtticus
1994 ZJ
why not just swap a 4.0 liter inline 6 into it?
http://cgi.ebay.co.uk/TVR-TUSCAN-SPE...QQcmdZViewItem
TslAtticus is offline
post #12 of 34 Old 10-20-2007, 09:57 PM Thread Starter
UltimatE
Resident Audio Guru
UltimatE's Avatar
I wonder how much power that TVR engine makes.
-Matt
White '94 YJ Sport
UltimatE is offline
post #13 of 34 Old 10-20-2007, 10:04 PM
TslAtticus
1994 ZJ
they make around 360-400hp depending on year and model so that one is probably a 360hp. you could drop that in, say its a 4.0 I6 to anyone that asks and you wouldn't be a liar.
brb, quad cam zj
post #14 of 34 Old 10-21-2007, 10:42 AM
BLACKzj52
supras will womp on any current day v8...
for the most part that is..
u cant beat those huge twin 67mm turbos
post #15 of 34 Old 10-21-2007, 01:02 PM
Jeeples
Jeeples's Avatar
Wanna know what a 600 HP, 800 HP, and a 1000 HP Supra have in common?
An 11 sec. ET*
Unless of course said Supra has a 200 shot of nitrous to help spool before the 1/8th mile mark
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
