Lower Control arms - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Lower Control arms
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 10-29-2008, 11:21 AM   #1
93JGC5.2L
Lower Control arms
I'm looking for front and rear lower control arms for my 93 GC. Apparently the area where the bushings are have rusted/blown out. I was wondering if anyone has any suggestions for replacement arms? Right now it is still at stock ride height and will probably be that way for awhile. Thanks!
93JGC5.2L is offline   Reply With Quote
Unread 10-29-2008, 11:58 AM   #2
-cAcHe-
www.rockauto.com
www.ebay.com- type in grand cherokee control arms and they should come up.
www.desert-hooligans.webs.com
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline   Reply With Quote
Unread 10-29-2008, 12:01 PM   #3
1sportsdoc
2010 JK Wrangler
The frt and rr lowers are very easy to replace. Replace one at a time, do not remove both frts or rrs at the same time ... sometimes it can be real tough trying to install the new ones because of the axle shifting. Not sure if your 93 has the cam adjusters on the front like my 96 does, if so, be sure to mark the location before removing. If you're staying stock, not much benefit in going to an aftermarket CA's other then less flexing. I think the cost difference between factory and aftermarket is close to the same, maybe the aftermarkets are a bit less expensive for the fixed length.
1sportsdoc is offline   Reply With Quote
Unread 10-29-2008, 12:40 PM   #4
CanadianZed-J
I'm pretty sure TJs use the same control arms. Anyone?
If that's the case they should be real easy to come by. Everyone who lifts a TJ (tons) no longer needs then and they're not a common part to replace so there's no demand. When I lifted my TJ I put up all the stock parts for free on our local Jeep forum and oddly enough, only the coils were taken for someone's other project. The CAs went to the dump.
Anyway, look into seeing if they're the same and you'll greatly increase your chances of finding some. And as stated, stay stock if the Jeep is stock. There's no real benefit to aftermarket, and if they're non-swivelling, you'll actually get less flex.
Almost forgot, hang on to those cam bolts if they're still good and you don't have to cut them out. I needed new ones from the dealer and they were $28 each for the bolt and $7 each for the nut. :O
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline   Reply With Quote
Unread 10-29-2008, 02:37 PM   #5
psychoworks
Where are you at in Pa?
There are PLENTY of GC's @ Harry's U Pull it in Hazelton. Trust me, I'm there almost every other day.
[I]I [B]shop[/B] in the salvage yard![/I]
psychoworks is offline   Reply With Quote
Unread 10-29-2008, 03:10 PM   #6
-Joe-
Yes TJ arms will fit all except rear lower.
You can probably find a fairly new set with bushings as well really cheap.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote
Unread 10-29-2008, 06:05 PM   #7
Kolak
Vendor
Kolak's Avatar
Holy cow! I grew up in Hazleton. A lot of my family is still there.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is offline   Reply With Quote
