Are the lower control arm cam bolts somehow different for a '93 ZJ? - JeepForum.com
post #1 of 2 Old 03-29-2013, 09:31 PM Thread Starter
scandent
For some reason the cams have been removed from my '93 lower control arm bolts. There is the u-shaped flange on the axle and slotted holes, but no cams. The problem is that because of this the bolt head hits the u-flange and wont allow adjustment to the end of the slot, and hence i cannot make the necessary caster angle. Im thinking that with the cams it will gain another 2-3mm of travel.
Now to the question at hand: Is the '93 bolt somehow different than the '94-up bolt? It seems that to find one specifically identified for the '93 it will cost the better half of a Benjamin; whereas these:
http://www.ebay.com/itm/MOOG-K100047...a2dfb3&vxp=mtr
are only about $14 bucks including shipping. Is there any difference?
scandent is offline
post #2 of 2 Old 03-29-2013, 09:58 PM
WhiteOut
WhiteOut's Avatar
Go nuts. No difference in cam bolts for the ZJ.
WhiteOut is offline
