Lower clock keeps turning off / resetting itself .. ?? - JeepForum.com
post #1 of 9 Old 10-11-2006, 06:08 AM Thread Starter
lawdogg
I looked through the FAQ and didn't see anything about it so maybe it's an uncommon thing. My lower info display screen only turns on intermittently and when it does, it always isn't the right date and it sits there and flashes.
Also, sometimes the rear wheels are blank (like how it fills them in to tell you 2WD/4WD?) ... well, it'll go away as if I was in no-wheel-drive. Is this bad?
I'm assuming a faulty connection, maybe a bad ground. But is it something more serious?
2002 WJ 4.0 - Blue Jeep Club #255 (totalled by drunk driver)
1994 3000GT VR-4 (11.8 @ 116, 17psi, pump gas & street tires)
lawdogg is offline
post #2 of 9 Old 10-11-2006, 08:02 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
A lot of times if the clock keeps resetting itself the battery is near the end of its life.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 9 Old 10-11-2006, 09:15 AM Thread Starter
lawdogg
Huh, battery is relatively new. I'll have to whip out the multimeter when I get off work.
So this hasn't happened to anyone else?
lawdogg is offline
post #4 of 9 Old 10-11-2006, 09:25 AM
ArloGuthroJeep
Mr. Hyde!
I did a search in the VIC (Vehicle Information Center) for something else yesterday and came across a lot of posts about low batteries and the clock resetting. Not saying that is what is wrong for sure with yours, just what others have experienced. You could have a bad gound, corodded battery terminals, or a loose connection etc...
post #5 of 9 Old 10-11-2006, 09:43 AM Thread Starter
lawdogg
Yeah it would make sense but the radio clock is fine.
I think it's a problem with that lower display. It turns off randomly (like the whole thing ... just black) and if I smack it it'll turn on sometimes.
lawdogg is offline
post #6 of 9 Old 10-11-2006, 05:11 PM
platinum5.9
2003 WJ
I am having the same exact problem with my 95 ZJ, sometimes it will stay off for a couple days, then I get in and it will be back on, but flashing the wrong time. I will set it because the flashing annoys me and then be on my way, and after a while I will look down and it will be black, completely off. Also mine was doing the same exact thing with the tires not lighting up too. I am assuming maybe the VIC itself is bad, but please let me know what you figure out and I will do the same, its very frustrating. Thanks!
platinum5.9 is offline
post #7 of 9 Old 10-11-2006, 05:48 PM
user jeep
i would start by removing the VIC and checking the connections, it really doesnt take that long
ZJ - 1995 Jeep Grand Cherokee
user jeep is offline
post #8 of 9 Old 10-12-2006, 05:46 AM Thread Starter
lawdogg
Alright I'll check that out. Where is it in the Jeep?
lawdogg is offline
post #9 of 9 Old 10-16-2006, 12:13 AM
Dempster_Runner
Try checking the fuses. My 93 Grand was doing that, changed a fuse and its good to go now.
Dempster_Runner is offline
VIC Clock keeps resetting itself SFABlazer2 ZJ Grand Cherokee Forum 15 02-11-2014 04:50 AM
Taking 4" LA's off, going lower, yes going lower, few questions TheSandman ZJ Grand Cherokee Forum 13 03-08-2009 12:33 PM
98 5.9 Electrical Problem clock panel resetting jcooperdj ZJ Grand Cherokee Forum 1 02-06-2005 07:59 AM
clock keeps resetting Camster ZJ Grand Cherokee Forum 7 01-22-2004 02:20 PM
center lower vehicle display clock keeps reseting gbd8977 ZJ Grand Cherokee Forum 4 09-15-2003 05:43 PM
