Low rpm issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Low rpm issue
Premium LED Lighting by VISION X, Proudly sold at ROCKRIDGFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WD
Unread 05-24-2014, 01:34 PM   #1
kildog65
Low rpm issue
I have the 5.2 v8 and I have been recently getting low rpms and occasionally stalls when is pull out if a parking spot or my drive way have any ideas what could be the problem?
kildog65 is offline   Reply With Quote
Unread 05-24-2014, 01:59 PM   #2
dellis
The Idle Air Controller would be one of the first suspects. Removal and cleaning with carburetor cleaner usually does the trick.
Air leaks or a bad coil (or some other part of your "spark" system such as plugs, distributor, plug wires) are other suspect areas. I just had a similar problem with low idle, stumbling idle, hesitation and dieing out of low RPMs ... and it turned out to be the coil:
http://www.jeepforum.com/forum/f13/d...-idle-2417169/
dellis is offline   Reply With Quote
Unread 05-24-2014, 04:07 PM   #3
newfieZJ
X2^
http://www.jeepforum.com/forum/f13/h...-valve-756934/
Check your plugs for oil fouling from a bad plenum gasket . Do a visual inspection when doing the IAC
newfieZJ is offline   Reply With Quote
