Low Oil, white smoke - JeepForum.com
post #1 of 10 Old 10-12-2009, 04:22 PM Thread Starter
JamesLouis
I've had around 10 vehicles, purchased all from private sellers, and of course this is the time I somehow forget to check the oil before I buy the jeep. I checked the oil level and there was NONE on the dipstick. I then drained the oil to see how much was actually in there; turned out to be 1.5 qts or so. Awesome, huh? So I put 5 qts in and started it up, lots of white smoke came out and some water dripped from the tailpipe. I'm guessing this means I have a blown head gasket and there is oil being burned in the piston cylinder? Might there be some other reason? I should also mention that after I started it up I drove it about 2 miles and came back and no more white smoke. I'm about to go for another ride to see if it comes back after I let it cool (I believe the thermal contraction of the fluids might pull some more oil back in if there is a leak). Any ideas/input?
JamesLouis
JamesLouis is offline
post #2 of 10 Old 10-12-2009, 05:21 PM
IslandManMitch
Drive it and keep a check on the oil level. See what it does. You could do a compression check if you really want to check something.
IslandManMitch is offline
post #3 of 10 Old 10-12-2009, 07:23 PM
vansskaterfreek
if its a v8 zj, its probably the pan gasket
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #4 of 10 Old 10-12-2009, 07:26 PM Thread Starter
JamesLouis
Sorry, it's a 99 V8 WJ. By pan do you mean oil pan? I did notice it looked a little oiled around where the oil pan meets whatever it's mounted to but it wasn't wet by any means. Can't imagine the 4qts leaking out there. Plus the oil filter looked new and is why I'm baffled. Although, with the things I've been finding I wouldn't be surprised if he just changed the filter to make it look like it had been well maintained. What a ****.
JamesLouis
post #5 of 10 Old 10-12-2009, 07:47 PM
vansskaterfreek
sounds like head gaskets then, the pan gasket was only the 5.2 and 5.9 in the 1993-1998 zj
post #6 of 10 Old 10-12-2009, 08:10 PM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
Could be worn valves or rings if the PO kept it that low for any signifcant amount of time. Keep an eye on it for a week or so, then if problems still are present have a compression test done.
WALTER
walter_da_jpr is offline
post #7 of 10 Old 10-15-2009, 10:21 AM Thread Starter
JamesLouis
After the initial cloud of smoke and condensation drip from the exhaust I haven't had any problems. Amazing what taking care of your vehicle will do. When I got this jeep it had a shifting problem (speed output sensor fixed that), a leaking radiator of about 60 drops per minute (alumasealed it, no leaks), vibrating during high speeds/stopping (replaced rotors) and a heater core problem which will not be so easily solved but still a cheap fix. Paid $2k for the Jeep and will have fixed everything for about $250. Wahoo.
JamesLouis
post #8 of 10 Old 10-15-2009, 10:25 AM
walter_da_jpr
I love cheap used vehicles that need a couple things. Can't beat it.
WALTER
post #9 of 10 Old 10-15-2009, 10:58 AM Thread Starter
JamesLouis
I like my vehicles like I like my women, cheap and broken.
JamesLouis
post #10 of 10 Old 10-15-2009, 12:19 PM
littlefdl
1994 ZJ
i agree i agree
littlefdl is offline
4.7 white smoke on startup then goes away UNDERDAWG ZJ Grand Cherokee Forum 9 04-25-2009 08:54 PM
White Smoke BRayf78 ZJ Grand Cherokee Forum 22 04-23-2008 12:14 PM
ZJ dieing? White smoke and oil in intake ZJcrawler45 ZJ Grand Cherokee Forum 5 03-25-2008 01:34 PM
5.2 White smoke on start-up? chiadrum ZJ Grand Cherokee Forum 18 01-17-2007 12:05 AM
Odorless white smoke from vents RobertTF ZJ Grand Cherokee Forum 11 07-12-2006 11:06 AM
