low oil pressure? - JeepForum.com
post #1 of 2 Old 07-05-2003, 02:58 AM Thread Starter
f14x4
low oil pressure?
IVE NOTICED RECENTLY THAT MY OIL PRESSURE HAS BEEN PRETTY LOW AT IDLE, LIKE THE GUAGE READS AROUND 20-25 AT IDLE. ONCE I GIVE IT SOME GAS ITS FINE AND IVE CHECKED FOR LEAKS AND ALL SEEMS WELL. I CHANGED MY OIL TODAY AND I STILL HAVE THE SAME PROBLEM. I USE QUAKER STATE 4X4 10W30 AND I ALWAYS USE THE MOPAR OIL FILTER.. THE ENGINE DOESNT RUN HOT AND I STILL GET ABOUT 6 QUARTS WHEN I DRAIN THE OLD OIL OUT. IM NOT SURE WHAT THE PROBLEM IS OR EVEN IF I HAVE A PROBLEM BUT IF IM NOT MISTAKEN SHOULDNT THE OIL PRESSURE BE AROUND 40 AT IDLE? IS IT POSSIBLE THAT THE WEATHER HAS ANYTHING TO DO WITH IT?
IM NOT SURE IF I SHOULD BE WORRIED OR NOT SO ANYONE WHO CAN GIVE ME SOME IDEAS WOULD BE APPRECIATED
(0IIIII0)
THERES ONLY ONE
f14x4 is offline
post #2 of 2 Old 07-06-2003, 02:21 AM
Dale
Dale's Avatar
what engine do u have? if its the I6 the oil pressure can go down to 13 psi @ idle(600rpm) and 35-75psi while driving. i think the 4-banger stays up higher. dunno about the v8.
Dale
Dale is offline
Changed my governor pressure transducer and a governor pressure solenoid but.....? 02Lightning ZJ Grand Cherokee Forum 12 12-21-2009 10:06 PM
Low oil pressure on 5.2 XJ ridebmx ZJ Grand Cherokee Forum 8 04-10-2009 01:47 PM
Oil Pressure shmo ZJ Grand Cherokee Forum 3 03-27-2006 03:25 AM
Low oil pressure on a 4.0 rblahetka ZJ Grand Cherokee Forum 4 03-20-2006 01:12 PM
oil pressure low 2000larado ZJ Grand Cherokee Forum 20 02-26-2006 03:19 PM
