Low oil Pressure - JeepForum.com
post #1 of 6 Old 12-27-2004, 11:40 AM Thread Starter
doghouse1212
Low oil Pressure
This is my first time on the forum so I'll try not to bore anyone. I just bught a 99 Grand Cherokee V8, I have started getting a check gauges lite. It on beacuse at an idle the oil pressure is real low. Any simple fix ideas aside from the oil pump??
doghouse1212 is offline
post #2 of 6 Old 12-27-2004, 02:09 PM
Meerkat
Just out of idle curiosity, how many posts does one have to have before he is allowed to bore people?
Your problem is most likely not the oil pump. The first thing to check is, of course, your oil level. If it is full, then the most likely culprit is the oil pressure sending unit. Which should be located on the forward end of the engine block just above the oil filter on your Jeep.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 6 Old 12-27-2004, 05:12 PM
cajunmudder
cajunmudder's Avatar
yeah i had the same problem last week. I checked the sending unit and there was oil everywhere and it was spinning around so i replaced it and it works great.
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
Custom Fiberglass Box
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
Dunlop 265/75/16 mud rovers
cajunmudder is offline
post #4 of 6 Old 12-27-2004, 05:29 PM
nagos420
Just replaced mine too, its most likely your problem also
nagos420 is offline
post #5 of 6 Old 12-28-2004, 11:57 AM
97grand
97grand's Avatar
Optimally, how high should the oil pressure be?
97 Grand Cherokee LTD 5.2L V8. 130k Black on Black; Gold Trim
Only mod's are a toddler seat and a spilled juice cup! SOLD
'91 Taurus SHO+ - Deep Jewel Green
'05 Grand Caravan SXT Inferno Red
'69 Dodge Charger - Black primer
97grand is offline
post #6 of 6 Old 12-28-2004, 12:46 PM
mr_user
I found that when the oil gets up to temp, which is a bit longer than when your engine gauge gets to temp, the oil pressure should be somewhere around 40/50. On the highway 60-65 for me is not uncommon.
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
Changed my governor pressure transducer and a governor pressure solenoid but.....? 02Lightning ZJ Grand Cherokee Forum 12 12-21-2009 09:06 PM
Low oil pressure on 5.2 XJ ridebmx ZJ Grand Cherokee Forum 8 04-10-2009 12:47 PM
Oil Pressure shmo ZJ Grand Cherokee Forum 3 03-27-2006 02:25 AM
Low oil pressure on a 4.0 rblahetka ZJ Grand Cherokee Forum 4 03-20-2006 12:12 PM
oil pressure low 2000larado ZJ Grand Cherokee Forum 20 02-26-2006 02:19 PM
