Low idle RPM, coolant temp. gauge is max, air bag light on? - JeepForum.com
post #1 of 1 Old 07-16-2011, 02:53 PM Thread Starter
shad366
I recently worked on my valve cover and throttle body. I just started the Jeep up, and the idle RPM is 500-800, and the air bag light is on. The coolant temp gauge is also maxed out. Any suggestions as to what this could be? Some coolant did leak out of the upper radiator hose when I took the valve cover off, and there is a chance the intake manifold gasket is not set right... Other than that, everything checks out. Could it be IAC? And maybe a failing coolant temp. sensor?
2002 Jeep Grand Cherokee 4.7 V8 WJ
shad366 is offline
Coolant Temp Sending Unit - to dash/gauge (not computer) Oxenhandler ZJ Grand Cherokee Forum 16 04-26-2015 01:27 PM
Temp Switch Sender/Coolant Temp Sensor pennyduke ZJ Grand Cherokee Forum 3 07-09-2011 10:08 PM
bad idle and bad coolant temp sensor Sontizzle ZJ Grand Cherokee Forum 6 07-29-2008 11:29 PM
coolant temp sensor for gauge a70eliminator ZJ Grand Cherokee Forum 1 01-27-2008 01:30 PM
93 ZJ coolant temp sensor - same one for gauge and PCM? Aceladriver ZJ Grand Cherokee Forum 30 01-21-2008 07:55 PM
