Low Idle/Dying When Not In Gear - JeepForum.com
post #1 of 5 Old 02-19-2009, 09:01 PM Thread Starter
tb123
I have a 2000 Grand Cherokee (4.0L) that just recently started having idle problems. When I first start the engine, the idle is really low (less than 500 rpm) and the engine usually dies. There are no noticeable problems once I am in gear and driving, but if I am in park on neutral, the idle drops or the engine dies. The idle is also low while I am stopped in drive. There are no check engine lights. I was thinking that I might need to replace the TPS or another sensor but I am not sure. Has anyone had a similar problem or know what I should try first? Thanks a lot.
tb123 is offline
post #2 of 5 Old 02-19-2009, 10:01 PM
Geisteskrank
i have a 97 4.0L and mine does something similar where it will try to stall if i am coming to a stop or if i am already stopped and shifting from park into reverse or drive. However when it first starts up it idles at around 1000 rpm then slowly decreases, then once it warms up it starts having the problems.
Does the ZJ have a TPS? I thought it was mechanically connected but i may be wrong.
In any case I also do not know what the problem is. Some people have recommended that I do a tranny fluid change and try replacing the downstream 02 sensor. I am going to try these soon.
Stock 1997 ZJ Laredo
4.0L select-trac
Geisteskrank is offline
post #3 of 5 Old 02-19-2009, 10:11 PM
crazydude2500
idle air control try that i had the same problem on my cherokee not my grand tho should be the same motor was my 4.0 in my 97 clean it out....mine was by the intake with 2 torx 15 bolts holding it in i cleaned mine and left it dry overnite now it starts and runs fine no problems....probably just have build up in there
pat
green lifted 4.5 w/32's custom front bumper 5.2L
97 xj stock blue tow hooks F&R 4.0L
2004 dodge neon SRT-4
crazydude2500 is offline
post #4 of 5 Old 02-20-2009, 07:27 AM
StrokedWJ
StrokedWJ's Avatar
Yeah, try cleaning out your throttle body first and see if that helps. I used some intake cleaner spray and a toothbrush to scrub it out. How old is your battery? Sometimes the WJ's do funny things with low voltage....
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #5 of 5 Old 02-23-2009, 09:23 PM Thread Starter
tb123
I cleaned out the throttle body and the sensors on it a couple of days ago and have not had any problems since then. Hopefully that fixed it. Thanks for the help.
tb123 is offline
ZJ shudders at idle in gear 250psd ZJ Grand Cherokee Forum 10 06-11-2012 09:01 AM
04 wj w/rough idle-vibration at stop in gear bimmerjeeper ZJ Grand Cherokee Forum 13 02-10-2010 03:42 PM
rattle in idle, stops when in gear xjPWN ZJ Grand Cherokee Forum 2 12-12-2009 04:56 PM
99' WJ 4.0 Just started to....... (rough idle in gear) 4jeepers ZJ Grand Cherokee Forum 4 02-28-2009 10:28 AM
How Much, If At All Should Idle Vary In And Out Of Gear? Briandl ZJ Grand Cherokee Forum 1 02-04-2006 09:23 AM
