"Low Coolant" warning light - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > "Low Coolant" warning light
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 08-05-2008, 06:35 AM   #1
dsl55
Having some random issues with this warning light. Sometimes on start up this light comes on, goes out when it fires and then comes back on after a second or 2. If you turn the car off and then start it again it often clears it.
I have checked the levels and they are all fine and can't see that this light is used as a warning for anything else
Any suggestions?
dsl55 is offline   Reply With Quote
Unread 08-05-2008, 07:39 AM   #2
Kruzin
The sensor in the overflow tank may be going bad.
DD: 98 ZJ Laredo 5.2, all stock
Wheeler/Beater: 93 ZJ Laredo
4.0, AW4, 231 conversion from 249
3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard
Colorado Jeep Club Member 242 (4.0L)
Kruzin is offline   Reply With Quote
Unread 08-05-2008, 01:11 PM   #3
CMARJEEP
my sensor went bad and did the same thing. they cost like $20 and take 2 seconds to swap out.
www.norcaljeepers.co
CMARJEEP is offline   Reply With Quote
Unread 08-05-2008, 01:14 PM   #4
JerseyJeeper
same thing is happening to mine....and its really annoying, my voc teacher told me that the sensor was prolly bad...
hella, RE 2", surco rack,
JerseyJeeper is offline   Reply With Quote
Unread 08-05-2008, 01:19 PM   #5
moparrr07
x4 for bad sensor
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline   Reply With Quote
Unread 08-05-2008, 01:50 PM   #6
dsl55
seems a concensus of opinion has been reached!! will get down the dealers tomorrow & get one ordered
thanks
