Low Battery Reading - Bad Ground? No Start!! - Page 2 - JeepForum.com
post #16 of 21 Old 07-24-2011, 01:27 PM Thread Starter
imajeepman
That's where I'm headed now, moved the laptop to the garage where I can update and respond sooner and easier...
imajeepman is offline
post #17 of 21 Old 07-24-2011, 02:09 PM Thread Starter
imajeepman
I've been letting my brother drive the Laredo since he doesn't have a car and havent been underneath for a month since I replaced the shift cable and change the pumpkin fluids. Turns out after going down there is oil covering the starter dripping all the way to the trans pan, I followed the flow and located the start as the intake. Am I right that the right amount of oil can burn the starter???
post #18 of 21 Old 07-24-2011, 02:46 PM Thread Starter
imajeepman
*Selenoid not starter
post #19 of 21 Old 07-24-2011, 03:03 PM
Mark05059
yes oil can be bad for a starter and solenoid. Try this. Turn the key to the on position (dont try and start it) block the tires so it cant roll and be sure that its in park. At the starter solenoid there are 3 wires. 2 Large gage wires and one smaller one. Expose the smaller wire so that you can see the post (meaning make it so you can see the metal post) Take a screw driver (or other metal object that has an insulated handle) and cross the small wire to the larger wire coming from the battery. It should turn over. If it does then the problem is in the wiring from the switch.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #20 of 21 Old 07-25-2011, 10:31 PM Thread Starter
imajeepman
By switch are you refering to the relay under the hood?
Pulled the Valve cover gasket and it was busted as well as motor mounts and the oil seemed to disburse from the oil sending unit.
All being replaced tomorrow then cleaning the starter/selenoid and attempting the bang first then the screw driver with rubber handle on the power cord - small wire post. Thanks guys and gal, will keep the updates and try to provide pictures - I'm gonna clean her up something good!! Love saving money!!
Hopefully become a Premium User soon!
post #21 of 21 Old 11-26-2013, 07:44 AM
JakeC132
I'm having this same issue, it happened right after my oil pressure sending unit went and sprayed oil all over the starter.. did your issue end up being the starter or solenoid?
JakeC132 is offline
bad starter or bad battery ground? signalmtnjeep ZJ Grand Cherokee Forum 5 11-26-2013 08:01 AM
JGC WJ 3.1TD won't start after battery disconnect techem ZJ Grand Cherokee Forum 2 02-07-2010 04:36 PM
95 ZJ will not start after installing battery JackAysJake ZJ Grand Cherokee Forum 3 09-09-2008 11:19 PM
95 ZJ won't start after unhooking battery Deschain ZJ Grand Cherokee Forum 8 09-26-2006 10:04 AM
battery dead, now won't start axhead ZJ Grand Cherokee Forum 2 05-06-2005 07:55 PM
