Loud popping in front end under load - JeepForum.com
post #1 of 4 Old 04-23-2013, 08:57 PM Thread Starter
shackwrrr
still working out all the kinks in my new jeep. I took it up into the woods on my property and played with it a bit. I noticed that if I get the front tires in a bind and give it some gas I get a loud popping noise as if splines are stripped somewhere. Are there any common failure points that could cause this.
The front does not spin when it does this, and it is not the VC. When I first bound up the front I could tell the VC was doing its job and it slowly started to grab, after that is when it started to pop. I have also gotten it to make the noise under hard acceleration on pavement or gravel.
Its a 93 v8
shackwrrr is offline
post #2 of 4 Old 04-23-2013, 10:45 PM
Roskoe
Check for lose parts and check bushings on sway bar & endlinks and Check UCA & LCA bushings
"aut viam inveniam aut faciam"
I hate when old people poke me at weddings, point and whisper, "You're next." So I've started doing the same thing to them at funerals
Roskoe is offline
post #3 of 4 Old 04-24-2013, 06:08 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Either the chain in the case or the differential is toast.
ratmonkey is offline
post #4 of 4 Old 04-24-2013, 08:08 AM
speedbucket
Could be CV axle shafts popping under load
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
