Loud engine - JeepForum.com
post #1 of 4 Old 07-08-2002, 09:26 AM Thread Starter
93BGU
Loud engine
I have a 1996 Jeep Grand Cherokee Laredo. It seems like the engine is real loud. It has the 4.0L in it. Does anyone know what this could be? It's loud anywhere from 25MPH-80MPH.
Thanks!
93BGU is offline
post #2 of 4 Old 07-08-2002, 11:42 AM
Drafter75
93BGU... is it engine noise or fan noise? There's a big difference.
A bad fan clutch can be be loud, especially if it's to the point where it's locking and not allowing the fan to freewheel at the normal driving speeds you mention. This can make for quite a roar. Anyway, that's the first and easiest thing to check.
Drafter75
Proud V8 ZJ/WJ owner of
1993-1998-1999-2002 model years.
Have you hugged your Jeep today?
Drafter75 is offline
post #3 of 4 Old 07-09-2002, 02:32 AM
GHJEEP94YJ
GHJEEP94YJ's Avatar
A friend of mine had the 95 and his prolbem is a crack in his manifold.
94 BLK & Red YJ
Sweet Rockford Fosgate System
Custom intake for my 4 Banger
Spray In Liner, Rancho RS 5000's
Use the long skinny pedal and you will be okay.
BLACK JEEP CLUB MEMBER #8
GHJEEP94YJ is offline
post #4 of 4 Old 07-09-2002, 08:21 AM
joe-doggs
cracked exhaust manifolds are routine on this engine - if this is the problem - take it out & have it welded by somebody that can do stainless steel welding - the advantage of welding VS buying a new on is that the old one is already stress relieved & will not continue cracking - Aluminum Head Welders in Aurbun Washington State are very good at doing these & the GM stainless steel tube manifolds - guy uses a Boeing aerospace material weldiong rod to fix these. ALSO - make sure the gring the flanges FLAT - AHW does this as well as these manifolds are usually warped & possibly twisted.
joe-doggs is offline
4.7 loud knocking from engine painted600rr ZJ Grand Cherokee Forum 11 12-04-2009 06:46 PM
Loud, clicking engine when cold grzesiuskow ZJ Grand Cherokee Forum 10 01-15-2008 08:49 PM
Reallly loud fan clutch before engine heats up? TSFSU ZJ Grand Cherokee Forum 2 07-26-2004 05:13 PM
Loud Engine?? TSFSU ZJ Grand Cherokee Forum 5 06-02-2004 08:15 PM
loud engine jeepguy1996 ZJ Grand Cherokee Forum 5 07-27-2003 05:48 PM
