loud clunking noise when driving - JeepForum.com
post #1 of 9 Old 06-13-2003, 10:06 AM Thread Starter
atlien928
atlien928's Avatar
when i'm going over a bump or making sharp turns then my jeep makes a loud clunking noise from somewhere near the wheels in the front. any ideas what this could be?
atlien928 is offline
post #2 of 9 Old 06-13-2003, 10:25 AM
lambar
I had some clunking noises a couple weeks ago. Turned out to be the sway bar link was disconnected, and rubbing up against the springs.
1996 GC Limited 5.2L
2" Coil Spacer
30" General Grabbers
lambar is offline
post #3 of 9 Old 06-13-2003, 10:42 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Lots of things to check.
1. Sway bar links,
2. Trac bar
3. Steering box where it connects to the unibody
4. Shock mounts
5. small cat lodged in engine compartment
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 9 Old 06-13-2003, 12:20 PM
Zaphod
SACPOWERTV.com
Zaphod's Avatar
1981 J-Series Truck
Yeah, always check for small household pets in your engine compartment every time you change your oil.
Also, try picking up the anti-cat skid plate from quadratec.com... solved all my problems.
Ryan
81 J20 8400#
"The existence of flamethrowers is proof that someone,
somewhere, said to himself, "I want to set those people
over there on fire, but I don't feel like walking over there to do it."
Zaphod is offline
post #5 of 9 Old 06-13-2003, 01:55 PM Thread Starter
atlien928
atlien928's Avatar
i looked under there and sure enough i saw this disconnected and the vertical piece rubbing the spring. what is it called and how much does it cost about to fix? could i do it myself or have the shop do it. i put it back in place, but i'm sure it will pop out again, must be broken some way.
thanks
post #6 of 9 Old 06-13-2003, 02:05 PM
lambar
Thats your sway bar link, the verticle piece has sort of a cup on the end, and the piece where you see that screw has a ball end, where it sits nicely on the link. You can remove the link without causing any ill will to your car. People sometimes remove these links when they are hitting the trails (the more expierenced people here should be able to explain it better than me).
If I remember right, I think you need a ratchet, and a allen wrench to remove the bottom link (newbee mechanic)
They do sell a part called "quick disconnects" which allows you to easily remove the sway bar link when your going on the tough trails. I think they are around 80 bucks or so.
2" Coil Spacer
lambar is offline
post #7 of 9 Old 06-13-2003, 04:36 PM
Stocker
Lambar's right, but IMO do not run without it connected when on the road; your handling will be affected, especially if you corner hard or need to suddenly swerve to avoid an obstacle (car, bike, kid, animal...). You disconnect it when you want more suspension flex.
Y'know, just looking at that pic makes me think the end link is bent. Don't have mine here right now to compare, but I think it should be straighter where it attaches to the sway bay.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #8 of 9 Old 06-16-2003, 11:40 AM
jiggajeeps
I have the same problem. Just went out to look and my link is completely disconnected on the passenger side. This is a relatively easy and cheap fix, as I did it on my XJ last summer. You can purchase the link kit with all the necessary hardware for less than $50, if I remember correctly.
By the way, you may as well do both sides because you have to disconnect both sides to do the job. I learned this one the hard way
Good luck, I'll be doing the same thing tonight!
Current:
'98 TJ SE, stock
Past:
'04 KJ Sport, '98 5.9 Deep Slate, FIPK2, Mopar ECU, '93 XJ Country, '92 YJ 4.0 5speed
jiggajeeps is offline
post #9 of 9 Old 06-16-2003, 10:58 PM Thread Starter
atlien928
atlien928's Avatar
let me know how that install went. i have an appointment for my jeep to take it to the shop next monday, so i think i'm gona have them install it, my cheap tools made in taiwan i dont think can handle torque on those bolts haha
front passenger tire DW. Loud clunking sound. slagehammer ZJ Grand Cherokee Forum 2 07-27-2008 03:06 AM
Loud And Hard Clunking Underneathe My Zj, Sounds Nasty! ZJForBreakfast ZJ Grand Cherokee Forum 12 01-17-2008 02:19 PM
Loud Bang While Driving - Check Engine Light debbie9339 ZJ Grand Cherokee Forum 1 11-24-2007 02:11 PM
Loud Clunking Noise???? littlebiggy3 ZJ Grand Cherokee Forum 5 06-24-2005 04:37 PM
Loud clunking from front end...help sfish ZJ Grand Cherokee Forum 2 09-06-2004 10:11 PM
