Quantcast Loud, clicking engine when cold - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Loud, clicking engine when cold
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 01-15-2008, 09:03 AM   #1
grzesiuskow
When i start my car at the morning when is really cold (15 to -5) for the first 5 min the engine is pretty loud and i hear a clicking noise (probably from the cylinders). I know that the car has to run on higher rpm to heat up which will make it louder, but what about the clicking noise, is it normal?
Engine oil level is good.
2002 WJ Sport. V8, Select-Trac, FM 50, K&N Flter
grzesiuskow is offline   Reply With Quote
Old 01-15-2008, 09:55 AM   #2
impuresoul2k3
What kind of oil are you using? 10w-30, 5w-30, etc? If its more of a ticking sound it might be lifter tick, especially if it goes away when it warms up.
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline   Reply With Quote
Old 01-15-2008, 10:00 AM   #3
grzesiuskow
10w-30 Mobil 1 Full Synthetic, so is the loud tick normal in cold temp.
"If its more of a ticking sound it might be lifter tick, especially if it goes away when it warms up." - Sorry, but have no idea what that means, but it all goes away after about 5 min when engine warms up
Old 01-15-2008, 11:49 AM   #4
highryder08
i run 5w-30 year round and experience a click when my WJ is warming up... my guess is valve noise.. i always wait for the jeep to warm up before i drive it... i dont think its a major concern
2000 WJ LTD. - 2in. BB. Pirelli Scorpion AT/R. Hella 500 Amber Fogs
2000 Black TJ Sport, 4.5in. Superlift, 33x12.5in BF Goodrich Mud-Terrain's, 15x10in Cragar Black Steelies, Mile Marker 9000lb. winch, Bestop Tire Carrier, Custom Made Rear Bumper, Hella 500's, ARB Snorkel, Uniden CB/PA, SOLD
Appalachin State Mountaineers- Back to Back to Back National Champions!!
Go Noles!!
highryder08 is offline   Reply With Quote
Old 01-15-2008, 12:45 PM   #5
impuresoul2k3
yeah if it goes away when warm, it's probably valvetrain noise, as long as you have good oil pressure, just don't get on it until its warm
Air hat spacer
Flowmaster muffler
Old 01-15-2008, 02:05 PM   #6
thebgkoolio
1994 ZJ
i have a click that happens until my jeep warms up. almost confident its from the valvetrain. thou its been like that for about a year and no problems yet, just let it warm up then drive it.
94 zj -108k body and motor -6k on trans -Rustys Engine Skid-Rustys T-Case Crossmember-Tom Woods Front Driveshaft-Flowmaster 50 Series Exhaust-IRO 3.5" F>R with adjustable track bars-31x10.5x15 kumho a/t on 15x8 powdercoated black steel wheels
thebgkoolio is offline   Reply With Quote
Old 01-15-2008, 03:24 PM   #7
txtumbleweed
Pretty normal. Isn't 5W-30 the recommended oil? Might help in really cold climate.
Y2K WJ 4.7
txtumbleweed is offline   Reply With Quote
Old 01-15-2008, 03:42 PM   #8
No_Return
I haven't found a 4.0 I-6 that does not tick when it's below 45 degrees. I've tried 10W-30 & 5W-30 Mobile 1 along with 3 different brands of filters. Still goes tick tick tick in the mornings. Anyhow My ZJ did it when it had 80K on it and it still did it when I sold it with 160K on it Still Running very strong.
Like the others said As long as you have good oil pressure at start up you are probably fine.
I always give my jeeps a good minute or so to warm up in the morning.
Great danger lies in the notion that we can reason with evil. Doug Patton.
No_Return is offline   Reply With Quote
Old 01-15-2008, 05:26 PM   #9
BzJeep
Unfortunately... I had what I thought was the same problem but it turned out to be one of those worst case scenerios. I'll have my Jeep back tomorrow hopefully - the entire top half of the motor was rebuilt. Ticking when the engine was cold led to ticking the whole time which eventually led to clanking. Threw three rods and the followers as well as the lifters were shot. Turns out three cylinders were misfiring and coolant was getting into the oil which explains my gradual loss of coolant and the engine overheating in Idaho out of absolutely nowhere!
[b]2008 Metropolitan Gray Mazda3S Sport[/b]
[b]2001 Steel Blue Grand Limited[/b] *SOLD*
[b]1993 Forest Green Wrangler[/b] *SOLD*
[b]Green Jeep Club Member #16[/b]
[url]http://www.cardomain.com/id/bzjeep[/url]
BzJeep is offline   Reply With Quote
Old 01-15-2008, 05:27 PM   #10
UUJ1
I wouldn't be using 10W-30 in cold weather, that's pretty thick oil. YOu'll see even if you do use 5W-30, you'll still get a "tick". That most definitely is you lifters. It takes a while for the oil to work it's way back up to the top of the motor when it's cold out. That's why the noise goes away when your motor warms up.
'99 4.7 WJ,
[B]
3" IRO/Addco rear sway bar/ 31x10.5 Pro Comp XMT's(Yes, I changed my mind and decided on these)/ Pro Comp Mountain Crawler soft 8's 15x7 w/3.75" BS[/B]
242 in my garage... still
UUJ1 is offline   Reply With Quote
Old 01-15-2008, 08:49 PM   #11
silentbob21
silentbob21's Avatar
wow... I love this Forum!! Yesterday I experienced this Ticking for the first time... very loud, and this morning when I started the Jeep same thing. Little scared that it might be major issue just starting... I have a Honda CBR that has some minor ticking, but its normal for that high revving motor.
I did just recently change my oil, running 10w-30 Mobil 1 same that was in it before the change... Tonight after work (12 hours) still 20 degrees outside, I did not get the ticking noise on startup... So Im not sure where to go from here.
I guess wait and see what happens... I definately dont want anymore probs from the WJ! haha
silentbob21 is offline   Reply With Quote
Glock Forum
