Loud clicking from engine bay - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Loud clicking from engine bay
JK specific skid plates from Clayton Off Road Mfg.RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comStainless Steel Door Hinge Pins
Unread 04-01-2014, 04:33 PM   #1
Shanebear
1994 ZJ
Hey guys. Recently noticed a loud clicking sound from the engine bay. The clicking frequency changes when I press the gas (clicks faster) as well. Coming from the left side of the bay, around the spark plugs. Any idea?
Shanebear is offline   Reply With Quote
Unread 04-01-2014, 05:15 PM   #2
Shanebear
1994 ZJ
Could this be the lifters ticking? Seems worse when it's cold
Unread 04-02-2014, 01:13 PM   #3
Welshy
sounds like lifters, maybe a wire arcing out/
Welshy is offline   Reply With Quote
Unread 04-06-2014, 08:34 PM   #4
Shanebear
1994 ZJ
Uploaded a short video to youtube recording the sound. Any ideas?
https://www.youtube.com/watch?v=AzMG...ature=youtu.be
Unread 04-06-2014, 09:35 PM   #5
dylantheheeler
Take off the serpentine belt and start it. Sounds like a power steering pump. That would rule out everything the belt runs anyways.
yo vivo. yo voy. yo soy. Jeep.
I live. I ride. I am. Jeep.
dylantheheeler is offline   Reply With Quote
Unread 04-17-2014, 02:44 PM   #6
Shanebear
1994 ZJ
Hey guys, still having problems figuring out the cause. Here's a better short video
https://www.youtube.com/watch?v=ZxlH...ature=youtu.be
Unread 04-17-2014, 02:51 PM   #7
Pierre_r
Pierre_r's Avatar
1989 XJ Cherokee
The video dont work.
Jeep Cherokee XJ 4.0 -89
Jeep Cherokee XJ 4.0 -90 (partsjeep)
Jeep Grand Cherokee 5.2 -93
Chevrolet Silverado 2500 6.5TD -94
Chevrolet C20 6.2 -82
Pierre_r is offline   Reply With Quote
Unread 04-17-2014, 02:59 PM   #8
Shanebear
1994 ZJ
Derp. Try that now
Unread 04-17-2014, 04:47 PM   #9
PolkaPower
Well I would start by removing the belt and starting it up for a minute to see if it goes away. If not, I would start pulling spark plug wires carefully with a pair of pliers and a gloved hand one at a time to see if the sound changes, or stops on any of the cylinders. But that's my best guess over the interweb. Good luck.
When you pull a plug wire to check put it back obviously before you go to the next. Do not pull your coil wire while it's running. I learned that the hard way.
Originally Posted by jabba974
"And yes, there is always a torque spec...but its not necessary...and takes way to much time...."
PolkaPower is offline   Reply With Quote
Unread 04-17-2014, 04:53 PM   #10
Anatoliy
Could it be a hole/crack in the exhaust manifold? Are you seing a decrease in power or mpg?
Anatoliy is offline   Reply With Quote
Unread 04-17-2014, 05:44 PM   #11
Shanebear
1994 ZJ
Thanks for the ideas guys! I've noticed no change in power or mpg at all
Unread 04-17-2014, 07:47 PM   #12
newfieZJ
Jeep Collector
newfieZJ's Avatar
Lifter noise if I ever heard one . What's the condition of the oil and what are you running ?
Shane , here's what I would do . Buy 2 cans of motor flush at Can Tire , 2 gallons of the cheapest oil , 1 gallon of good , 2 filters from NAPA .
Follow instructions and add first can/bottle of flush . Drain the oil , change filter , install new oil . Run for 15 mins , repeat flush and finish with new oil . If that don't work , your looking at a new cam/lifter set and you will need to gently hone/clean each port for every lifter in the block .
newfieZJ is offline   Reply With Quote
Unread 04-17-2014, 08:06 PM   #13
Shanebear
1994 ZJ
I changed the oil and filter about 4500 km's ago. I used Castrol GTX High Mileage 10W30! REALLY appreciate the detailed advice by the way.
If weather is decent tomorrow I'll give it a go
