Lost My LCA Install Instructions - JeepForum.com
post #1 of 4 Old 10-05-2010, 10:38 AM Thread Starter
rooster51
Trying to kill my DW, got a set of front fixed LCA's. Can I replace these on the ground or do I put the body on jackstands, the axle on jackstands, or both.
Mucho Thanks.
Terry
rooster51 is offline
post #2 of 4 Old 10-05-2010, 10:46 AM
Yardman Harry
O
Yardman Harry's Avatar
do one at a time so that the axle doesnt shift too much. it is not necessary to jack the jeep up or take the tires off. I have done this many times with the jeep just sitting there parked.
here's a good trick you might find handy. to push the pinion down away from the jeep, use the stock bottle jack between the frame and the edge of the pinion. Works pretty good and no need to fuss with ratchet straps and chains, or jacking the axle up and down to try to get it to line up.
Yard
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #3 of 4 Old 10-05-2010, 10:49 AM Thread Starter
rooster51
Thanks, Harry. I didn't think of the bottle jack trick, good idea. Going to do it now. Thanks again.
Terry
post #4 of 4 Old 10-05-2010, 10:50 AM
Yardman Harry
O
No prob, I find that due to the angle the bottle jack is at on the frame it tends to slip sometimes, so I jam a wrench between the jack and the TB mount to keep the jack from slipping under the pressure.
Yard
Hunter Green
White
~Junked~
ZJ external spare tire install instructions needed tbbras ZJ Grand Cherokee Forum 0 06-24-2010 11:56 PM
5.2 water pump install instructions nickwygant ZJ Grand Cherokee Forum 3 05-09-2009 02:11 AM
Looking for the RR Commander lift install instructions tjthorson WK Grand Cherokee & XK Commander Forum 0 09-26-2008 07:11 AM
ARB Bulbar install instructions drewman141 ZJ Grand Cherokee Forum 7 04-08-2006 08:19 PM
Install Instructions (Rusty's 2" BB) grovesj2 ZJ Grand Cherokee Forum 7 04-15-2005 08:13 PM
