Losing coolant - No oveheat ~ No Leaks - JeepForum.com
post #1 of 10 Old 08-28-2009, 02:37 PM Thread Starter
SouthSeaPirate
Recently replaced rad, rad cap and thermostat. New gaskets on WP and thermo housing. On a side note; new clutch fan...
No oil in water and no water in oil. Its not over heating, no where near it. And I cannot find any leaks.
Its also not taking the water from the reservoir. It stays just as full as always even if the water in the rad goes down...
On other side notes that my not be related: Heater does not blow hot and there is water in the pass floorboard (guessing from A/C)
What am I missing? Is there some inconspicuous place I havent searched?
SouthSeaPirate is offline
post #2 of 10 Old 08-28-2009, 03:10 PM
jeepin161
could be a leak in the heater lines inside the truck
'93 Limited
3.5" Skyjacker Lift
33x13.5 Super Swamper LTBs
HID Fogs, Flowmaster Super 44
jeepin161 is offline
post #3 of 10 Old 08-28-2009, 03:15 PM
Virmagicus
Virmagicus's Avatar
^^ possible
Also, sometimes coolant can get burned and evaporate really fast if it is near the engine. Check the upper hose.
Jeff
Virmagicus is offline
post #4 of 10 Old 08-28-2009, 03:25 PM Thread Starter
SouthSeaPirate
Originally Posted by Jeep View Post
^^ possible
Thanks guys. How would I check for this?
I take it that would explain the water on the pass floor and why the heater wont work? This is why I thought it was the A/C: http://www.jeepforum.com/forum/3885949-post30.html (From the ZJ FAQ'S)
Upper rad hose lays right on top of the A/C compressor, and that fooker gets hot. The heater hoses run right next to the valve cover. Isnt that where there supposed to be?
post #5 of 10 Old 08-28-2009, 05:59 PM Thread Starter
SouthSeaPirate
Was just informed by the roomy that the WP is pouring out water from behind the pully. And it tore the belt, not sure how in the hell it did that...
Fook!
post #6 of 10 Old 08-28-2009, 08:19 PM
Virmagicus
Virmagicus's Avatar
Ahhh the pulley itself is probably wobbling like a mother as well. Make sure you check and make sure it is not leaking at the bypass hose though .
Jeff
post #7 of 10 Old 08-28-2009, 08:57 PM
FortCollinsZJ
Try Napa for a new water pump, great deals. then take an afternoon to replace it yourself and save 300 over having a shop do it.
FortCollinsZJ is offline
post #8 of 10 Old 08-28-2009, 09:11 PM
blackjack12982
1994 ZJ
Fook!
It tore the belt and is leaking because the bearing in the water pump is toast! I just had this problem earlier this month. Mine didn't tear the belt, but I was pouring out coolant like crazy whenever I would idle, not so much while driving. Brand new water pump w/ lifetime replacement warranty at Advance ran $70ish, no core.
blackjack12982 is offline
post #9 of 10 Old 08-28-2009, 10:39 PM Thread Starter
SouthSeaPirate
NAPA is double the price.
And I already know how to do it LOL. It was off not even 2 weeks ago.
Makes sence. Paid $42 at AZ w/ lifetime.
post #10 of 10 Old 08-29-2009, 03:10 AM Thread Starter
SouthSeaPirate
New pump, gaskets and thermo installed. We will see over the next couple of days to see how she does and of course keep filling it as air comes up.
So far in the last two weeks Ive replaced WP, belt, radiator, gaskets, thermo and clutch fan. Sheesh, money and patience only goes so far LOL. And yes they were all bad...
Losing coolant, not running hot reichhartkg ZJ Grand Cherokee Forum 2 06-01-2009 09:44 PM
Losing coolant trishareporter ZJ Grand Cherokee Forum 14 06-28-2007 03:13 PM
Losing Coolant dogbait ZJ Grand Cherokee Forum 9 07-23-2005 08:56 PM
Losing Coolant and Oil Pressure low at warm idle JeepCobbler ZJ Grand Cherokee Forum 3 08-30-2004 09:29 AM
Losing Coolant - 2002 GC JeepCobbler ZJ Grand Cherokee Forum 3 08-19-2004 01:06 PM
