Lose steering issue - JeepForum.com
post #1 of 17 Old 04-23-2013, 10:13 AM Thread Starter
RebelJeep1998
Lose steering issue
I have a 1998 Grand Cherokee with a 2 inch lift and 265/70/16 tires. This is the first Jeep I have owned and the steering on it seems to be really lose. When I drive is snow or slush it will actually throw me all over the road. Just curious what I should be looking for to fix? Steering stabalizer? Steering box going bad? Any info would be great.
Thanks
RebelJeep1998 is offline
post #2 of 17 Old 04-23-2013, 03:20 PM
Midnightluckey
Get someone you trust to get behind the wheel and shake it back and forth. While they do that, look under the hood at the steering shaft and box, and at the steering linkage between the box and axle. it should be fairly obvious where your play is after that.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #3 of 17 Old 04-23-2013, 03:43 PM
Pawjob
If you dont find any play in your steering linkages you can tighten your steering box up. Tighting your steering box will do nothing if you have play in your tie rod ends. There is an allen head screw on top of the steering box. Turn it a 1/4 way in and drive it. If its good then your done if not do another 1/4 turn. If you cant adjust it any more and there is still play. Time for a new steering box.
1994 Grand Cherokee Daily Driver
7" IRO Long arm, 35" Cooper Discrover STT. And more
1993 Wrangler, Rock Smashing Jeep, and November 2012 YJOTM...
1.5" SOA, Stak 3 speed Tcase, 37" Swamper M16's...ALOTS of extras
Pawjob is offline
post #4 of 17 Old 04-23-2013, 11:25 PM Thread Starter
RebelJeep1998
I tightened the allen head screw tonight and will take it for a drive tomorrow. Will let you know how it turns out.
post #5 of 17 Old 04-24-2013, 12:51 PM Thread Starter
RebelJeep1998
Well the allen head screw has been tightened total of half a turn and it still is lose. I could still turn the allen head screw so should I try turning that in further? Or should I just replace my steering box?
post #6 of 17 Old 04-24-2013, 11:17 PM
shaynesaw
Same thing was happening to me. No lift.
Just the alignment.
shaynesaw is offline
post #7 of 17 Old 04-25-2013, 12:08 AM
rozco
I had the same problem. Finally put in a new box and it was a whole lot better. Still not perfect but definitely better. I'm convinced it's either my steering on my axle or just that fact that it's lifted and pushing 33s and it will never be perfect
93' ZJ - 5.2L. 4.5" IRO lift. front long arms rear short adjustables. bilsteins. daystar bumps. 33" KM2's. rancho ss. rc quick discos. flowmaster 10 series.
rozco is offline
post #8 of 17 Old 04-25-2013, 08:48 AM
Pawjob
Lot of times its worn out tie rod ends, and/or the steering geometry. On my YJ im running the stock 1993 steering box, no stabilizer, pushing 37's at 70mph on the freeway no pulling, bump steer, sloppy or touchy steering. So just cause your lifted doesn't mean you have to settle for ok steering you can get it perfect. When I start building my ZJ here in the next month ill be putting the same set up under it as the YJ has. Using the Teraflex knuckle, 1.50 .250 wall DOM tube for drag link and tie rod. I dont use normal tie rod ends I use rod ends.
Pawjob is offline
post #9 of 17 Old 04-25-2013, 08:50 AM
DickDickle
What causes bump steer? I seem to have a little of that going on
DickDickle is offline
post #10 of 17 Old 04-25-2013, 09:17 AM
Pawjob
Steering geometry
Pawjob is offline
post #11 of 17 Old 04-28-2013, 01:43 PM Thread Starter
RebelJeep1998
Yeah I have come to cunclusion I'm going to replace the steering gear box and go from there. It seems to have gotten worse since I messed with that allen head screw. So not sure what the deal is.
post #12 of 17 Old 05-03-2013, 08:27 AM Thread Starter
RebelJeep1998
Ok just need some advice. Got paid today and am going to purchase the steering gear box. Should I just buy a new one or can I buy one from a salvage yard? What's everyones opinion?
post #13 of 17 Old 05-03-2013, 08:35 AM
DickDickle
Don't get a used one your just going to have the same problems all over again
post #14 of 17 Old 05-03-2013, 09:17 AM Thread Starter
RebelJeep1998
Ok thanks for the advice.
post #15 of 17 Old 05-03-2013, 09:49 AM
Pawjob
I just bought another ZJ, the front end wasnt set up right and im having the same loose steering issues. While inspecting the front end I noticed that the castor was set almost straight up and down about positive 2 degrees. On my set up I believe this to be the reason for loose steering. Castor should be around 4.5 degrees negative. Just something you can check before you go dropping money on a steering box.
Pawjob is offline
