-   -   Lose steering issue (http://www.jeepforum.com/forum/f13/lose-steering-issue-1513353/)
RebelJeep1998 04-23-2013 10:13 AM
Lose steering issue
I have a 1998 Grand Cherokee with a 2 inch lift and 265/70/16 tires. This is the first Jeep I have owned and the steering on it seems to be really lose. When I drive is snow or slush it will actually throw me all over the road. Just curious what I should be looking for to fix? Steering stabalizer? Steering box going bad? Any info would be great.
Thanks
Midnightluckey 04-23-2013 03:20 PM
Get someone you trust to get behind the wheel and shake it back and forth. While they do that, look under the hood at the steering shaft and box, and at the steering linkage between the box and axle. it should be fairly obvious where your play is after that.
Pawjob 04-23-2013 03:43 PM
If you dont find any play in your steering linkages you can tighten your steering box up. Tighting your steering box will do nothing if you have play in your tie rod ends. There is an allen head screw on top of the steering box. Turn it a 1/4 way in and drive it. If its good then your done if not do another 1/4 turn. If you cant adjust it any more and there is still play. Time for a new steering box.
RebelJeep1998 04-23-2013 11:25 PM
I tightened the allen head screw tonight and will take it for a drive tomorrow. Will let you know how it turns out.
RebelJeep1998 04-24-2013 12:51 PM
Well the allen head screw has been tightened total of half a turn and it still is lose. I could still turn the allen head screw so should I try turning that in further? Or should I just replace my steering box?
shaynesaw 04-24-2013 11:17 PM
Same thing was happening to me. No lift.
Just the alignment.
rozco 04-25-2013 12:08 AM
I had the same problem. Finally put in a new box and it was a whole lot better. Still not perfect but definitely better. I'm convinced it's either my steering on my axle or just that fact that it's lifted and pushing 33s and it will never be perfect
Pawjob 04-25-2013 08:48 AM
Lot of times its worn out tie rod ends, and/or the steering geometry. On my YJ im running the stock 1993 steering box, no stabilizer, pushing 37's at 70mph on the freeway no pulling, bump steer, sloppy or touchy steering. So just cause your lifted doesn't mean you have to settle for ok steering you can get it perfect. When I start building my ZJ here in the next month ill be putting the same set up under it as the YJ has. Using the Teraflex knuckle, 1.50 .250 wall DOM tube for drag link and tie rod. I dont use normal tie rod ends I use rod ends.
DickDickle 04-25-2013 08:50 AM
What causes bump steer? I seem to have a little of that going on
Pawjob 04-25-2013 09:17 AM
Steering geometry
RebelJeep1998 04-28-2013 01:43 PM
Yeah I have come to cunclusion I'm going to replace the steering gear box and go from there. It seems to have gotten worse since I messed with that allen head screw. So not sure what the deal is.
RebelJeep1998 05-03-2013 08:27 AM
Ok just need some advice. Got paid today and am going to purchase the steering gear box. Should I just buy a new one or can I buy one from a salvage yard? What's everyones opinion?
DickDickle 05-03-2013 08:35 AM
Don't get a used one your just going to have the same problems all over again
RebelJeep1998 05-03-2013 09:17 AM
Ok thanks for the advice.
Pawjob 05-03-2013 09:49 AM
I just bought another ZJ, the front end wasnt set up right and im having the same loose steering issues. While inspecting the front end I noticed that the castor was set almost straight up and down about positive 2 degrees. On my set up I believe this to be the reason for loose steering. Castor should be around 4.5 degrees negative. Just something you can check before you go dropping money on a steering box.
The time now is 04:17 PM.
