Loose wires behind VIC - JeepForum.com
post #1 of 18 Old 06-08-2013, 10:27 AM Thread Starter
zj97ltd
I'm assuming they're just for an option that I don't have, but figured I'd post a pic just to be sure. My VIC doesn't work so I thought I'd check the solder joints before I pitch and cubby the hole.
zj97ltd is offline
post #2 of 18 Old 06-08-2013, 10:42 AM
KyleSekora
There's two loose wires behind the vic because depending on which t-case you had determines which two wires they connected together and which two they left disconnected.
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[ ]llllll[ ]
_.(o)_)__(o)_)---)_)
KyleSekora is offline
post #3 of 18 Old 06-08-2013, 11:00 AM Thread Starter
zj97ltd
Figured it was something like that. Thanks!
zj97ltd is offline
post #4 of 18 Old 06-08-2013, 11:32 AM
dnuccio
hes right, but the wires you are showing arent the wires for the 4wd indicators. almost looks like those are spliced into the cigarette lighter or the power plug?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #5 of 18 Old 06-08-2013, 12:31 PM Thread Starter
zj97ltd
Not sure. Both outlets work and the VIC plug looks fine. My VIC is dead so time for a cubby.
zj97ltd is offline
post #6 of 18 Old 06-08-2013, 12:50 PM
dnuccio
thats the best solution
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 18 Old 06-08-2013, 06:13 PM
tucsonzj
I'd give you my VIC but it's from a 95 so wouldn't work haha. I put in my cubby last week. Best mod I've done....ever.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #8 of 18 Old 06-08-2013, 06:19 PM
savannahzj
How will you know when your coolant sensor is bad???
savannahzj is offline
post #9 of 18 Old 06-08-2013, 06:22 PM
tucsonzj
according to the VIC it's always bad.
tucsonzj is offline
post #10 of 18 Old 06-08-2013, 10:55 PM
KJK
Best mod ever is the MOPAR cupholder insert.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #11 of 18 Old 06-09-2013, 07:18 PM
KyleSekora
? Never heard of this one and couldnt find anything on it lol.
______ooooo
/__l_l_,\____\,___
post #12 of 18 Old 06-10-2013, 05:46 AM Thread Starter
zj97ltd
I believe it's a niner option. It's what makes them so fast.
zj97ltd is offline
post #13 of 18 Old 06-10-2013, 05:48 AM Thread Starter
zj97ltd
The VIC on my '97 Orvis worked as it should. It was kinda nice knowing that I was about to run out of washer fluid before I actually did, and little stuff like that. But, could always use more storage.
zj97ltd is offline
post #14 of 18 Old 06-10-2013, 06:26 AM
txbass06
Maybe that's why my 5.2 didn't want to start when I had the console out last. It missed the cup holder insert
txbass06 is offline
post #15 of 18 Old 06-10-2013, 10:25 AM
monkeyhouse
That's funny, I have a black wire with a slide on connector, I figured it was to a light for the ashtray? Somebody removed the ashtray at some point though, lol. Wow, I need to search on the cubby mod, sounds interesting!
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
