Loose steering / Alignment issues - JeepForum.com
post #1 of 3 Old 02-14-2011, 06:41 PM Thread Starter
Majobe2003
First post, so bear with me. Here goes:
I recently bought at '98 ZJ 4.0 with the 242 TC. It has a 3.5" lift with 33x12.50 15s and the stock front upper control arms. While talking with a few knowledgeable folks, I was told to replace the stock upper CAs with adjustable CAs. I got the new CAs in the mail today, and plan to start the project tomorrow.
Here are my questions:
1. My steering is loose; I have checked all the parts for wear and tear, everything is solid. My caster is currently something like +9 degrees from vertical, and my front axle has a 7 degree slope from TC to differential. How far should I shift my front axle to get it into spec? How far can I push the pinion angle without too many vibes? (This is my daily driver, so stable steering trumps flex)
2. How far forward can I push my front axle? I have trimmed about as much as I can, and bent all the pinch welds flat to the unibody, but I still rub when the front end flexes. Where should the front axle sit relative to the wheel well and can I use the adjustable CAs to push it forward a fraction of an inch? I have a custom front bumper and am willing to trim the fender, but I cant trim any more from the rear without cutting out spot welds and damaging the integrity of the unibody.
3. Does anyone have any tips/tricks to re-centering the axle and getting my alignment right after I get the new CAs in?
Any help would be genuinely appreciated. Snide remarks and laughter at the FNG will be tolerated with as much good humor as I can muster.
Majobe2003 is offline
post #2 of 3 Old 02-14-2011, 08:26 PM
TallyZJ
Check your other identical post. I answered.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #3 of 3 Old 02-15-2011, 01:26 PM Thread Starter
Majobe2003
Thanks.
alignment , caster , control arm
Issues getting alignment due to bushings teklokster ZJ Grand Cherokee Forum 3 07-13-2010 10:26 PM
got my 3.5" lift into my 5.9... now i have steering and alignment issues. cirame1 ZJ Grand Cherokee Forum 7 06-23-2009 02:39 PM
broken steering column / steering wheel loose? theksmith ZJ Grand Cherokee Forum 2 04-19-2009 09:49 PM
Alignment issues QuadraTokn ZJ Grand Cherokee Forum 5 03-25-2007 08:06 PM
Alignment issues? QuickZJ360 ZJ Grand Cherokee Forum 7 12-18-2005 08:16 PM
