Loose Spring? - JeepForum.com
post #1 of 10 Old 02-24-2008, 08:23 PM Thread Starter
Jammer73
Loose Spring?
G'day, after breaking my front drivers spring about 6 mths ago, I had them replaced them with OME's (and shocks). Every once and while I'd get a 'rebounding spring-like' clunking noise come from the drivers side while going over an assortment of big/small/medium undulations in the road. It has started to do it alot now, & I confirmed it was in fact the spring tonight, by having the old man rocking the front up & down while I was holding the spring. Sure enough a 'springy' clunk on each upwards & downwards compression vibrating into my hand.
Can these things come loose / unseated? Easy to fix? I doubt the spring is broken, but do I have a case to ask for a warranty on the mechanics work (assuming nothing is physically broken)?
Thanks
Jammer73 is offline
post #2 of 10 Old 02-24-2008, 08:26 PM
Virmagicus
Virmagicus's Avatar
Is the coil correctly seated now where it is supposed to be?
Jeff
Virmagicus is offline
post #3 of 10 Old 02-24-2008, 08:35 PM
Inavacuum
there should be a coil spring retainer clip that keeps the coil properly seated in the coil bucket. My guess is whoever put the new coils in forgot about or lost the retainer clip. Look on the other side and see if the coil is held in its bucket with a little clip.
http://www.4x4wire.com/jeep/tech/sus...tfremoved2.jpg
The bolt in the picture should be holding down a little clip that keeps the coil in place when no weight is on it.
95 ZJ 4.0 PART OUT: Silver Body; Grey Cloth interior
HPD30;RE BB w/ RE Shocks;KOR Rad Support
KOR XMember/TC Skid
Make an offer on anything you're interested in.
Inavacuum is offline
post #4 of 10 Old 02-24-2008, 08:39 PM Thread Starter
Jammer73
Yeah, it looks like it is seated correctly. Can the upper / lower isolators come loose?
Thanks inavacuum, will look for the retaining clip when I get home from work.
Cheers
Jammer73 is offline
post #5 of 10 Old 02-24-2008, 08:43 PM
Inavacuum
I don't know about the WJ but ZJs only have an isolator up top. I'm pretty sure even when the coil isn't pressing on it that it stays put. That could be just because its had so much pressure on it since it was put there though.
KOR XMember/TC Skid
post #6 of 10 Old 02-24-2008, 09:10 PM Thread Starter
Jammer73
Do WJ's have a coil spring retaining clip like the ZJ's?
Jammer73 is offline
post #7 of 10 Old 02-24-2008, 10:01 PM
silentbob21
not to my knowledge, never seen them on my 04
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline
post #8 of 10 Old 02-24-2008, 10:09 PM
Virmagicus
Virmagicus's Avatar
Nope, they sure don't. People talking out their butt again.
Jeff
post #9 of 10 Old 02-24-2008, 10:16 PM
Virmagicus
Virmagicus's Avatar
Check and make sure you don't have any play in the upper or lower trackbar mount transferring to the coils just to make sure.
Jeff
post #10 of 10 Old 02-24-2008, 10:21 PM Thread Starter
Jammer73
Will do. Thanks!
Jammer73 is offline
is my tie rod loose? mselby ZJ Grand Cherokee Forum 10 10-23-2009 03:11 PM
Why is this loose? Windowsrookie ZJ Grand Cherokee Forum 5 03-09-2008 04:06 PM
something seems loose jeep0104 ZJ Grand Cherokee Forum 7 03-16-2007 07:49 AM
Good Spring, Bad Spring? *Pics* micifus ZJ Grand Cherokee Forum 15 08-05-2006 01:28 PM
Loose Steering RAZZMANIAC ZJ Grand Cherokee Forum 1 06-20-2005 01:29 PM
