loose cold steering? - JeepForum.com
post #1 of 11 Old 01-18-2014, 04:41 PM Thread Starter
Gearhead31
Since getting the vc replaced, my steering feels rather loose when i initially leave work, I.e. motor isn't fully warmed up and it's highway travel. There's nearly double the play in the steering until it gets warmed up, then it's roughly 3/4" of a turn from tdc on the steering wheel to maintain straight on flat, level ground. If it were loose all the time, that's kinda a no brainer, but only when cold and only after a new vc? Or is this normal and I'm just used to a bad vc?
Sent from mobile, where errors are common and I'm too lazy to correct them.
Gearhead31 Hooah!
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #2 of 11 Old 01-18-2014, 04:47 PM Thread Starter
Gearhead31
There's also a weird oscillating vibration and hum that pulses through the steering wheel when in OD and accelerating from 60 to 65(only in that speed range) without kicking out of OD. I'm assuming that is related to worn motor mounts and a humming r&p, but it's there if that correlates to the main problem.
Gearhead31 Hooah!
post #3 of 11 Old 01-19-2014, 12:45 PM Thread Starter
Gearhead31
Anyone?
Gearhead31 Hooah!
post #4 of 11 Old 01-19-2014, 01:15 PM
PolkaPower
I tried tightening up my stub shaft on the steering box and the over the top adjustment with little success. I ended up Buying a new PSC steering gear. That pretty much solved that problem. Also replaced all of the control arms.
PolkaPower is online now
post #5 of 11 Old 01-19-2014, 03:26 PM Thread Starter
Gearhead31
Ew.. is this something i should be worried about or can I probably get away with leaving it alone for a few months? I have pretty much zero money to put into it right now and that's around $100+ iirc
Gearhead31 Hooah!
post #6 of 11 Old 01-19-2014, 03:29 PM
PolkaPower
That's up to you. I drove around with it like that for over a year. After I tried everything, I finally broke down and got a new gear. They went on sale and that was the deciding factor. I think I paid 375 and normally it was 450.
post #7 of 11 Old 01-19-2014, 04:00 PM
newfieZJ
Sounds kinda normal to me , the bad VC may have felt different . Your steering doesn't sound like it has all that much play . Have you checked all the TRE's properly ? Tire pressures even ? Those box adjustments are hit and miss . Last one I did feels great , others I have done felt better but now needs replacing , some made zero difference . It's a temp fix IMO , if the issue . Polka mentioned the control arms , I tried just the 2 front lwr axle bushings . It was much better , Then I replaced the other 2 on the frt lwr rear . It's good now . Rest are original . No more wandering . If you have original bushings , order a pair of lower XJ arms when you can , they will have solid bushings . It's a great ideal to get all new , but , the lower fronts have taken the most abuse and beat to death . When you think about it , at 19 years old , every piece of rubber on the suspension and drive train is pretty much spent .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #8 of 11 Old 01-19-2014, 05:48 PM Thread Starter
Gearhead31
its possible i found some of the problem
Gearhead31 Hooah!
post #9 of 11 Old 01-19-2014, 07:01 PM
PolkaPower
Yea, a leaky CV isn't usually the culprit of funny handling unless it's really bad. But good find.
post #10 of 11 Old 01-19-2014, 07:31 PM Thread Starter
Gearhead31
Woops, i meant about the oscillating vib/humming on acceleration. I went to do an alignment and its just about dead perfect but i found that. My steering box also had a good leak so that may be part of the culprit on loose handling. Worn rubber parts is probably part of the rest
Gearhead31 Hooah!
post #11 of 11 Old 01-20-2014, 05:49 AM Thread Starter
Gearhead31
I'm thinking it's probably that. TREs? The rubber parts still look like they have some life left in them but i can safely assume they are worn out anyways due to mileage alone.
A pair of XJ arms? I would've figured there would be a little length difference there, cool. I figure if i replace all the bushings between the tires and power steering pitman(?) Arm, that will probably fix most of it.
Thanks all! Hopefully that's all that the problem is. I'll have to get the presses and stuff to deal with that cv leak and start on replacing all the rubber under there
Gearhead31 Hooah!
