Looking to start building a ZJ need info - JeepForum.com
post #1 of 22 Old 01-18-2013, 10:26 PM Thread Starter
Pawjob
Like the title says I want to build a ZJ for DD and medium trail use so I can buggy my wrangler. That being said Ive looked at all the ZJ but not sure what model would be the best platform to build on. Ill be swapping my lockers and gears into a XJ HP dana 30 and getting a bracket kit for my Dana 44 rear so axles wont be an issue. Also I was looking at Ironrockoffroad 7" long arm kit. They any good?...I want to clear 35's and would be nice to clear 37's.
Pawjob is offline
post #2 of 22 Old 01-19-2013, 05:04 AM
xxxxxxxxranger_1999
Guest
xxxxxxxxranger_1999 is offline
post #3 of 22 Old 01-19-2013, 06:49 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Clayton long arms
Trim the hell out of your fenders
You can get 35's under there at 4.5".
37's are too much for an hp30/44 set up under a zj.
Buy a 96-98 v8 for your base platform.
ratmonkey is offline
post #4 of 22 Old 01-19-2013, 07:03 AM Thread Starter
Pawjob
Originally Posted by ranger_1999 View Post
I did read through that but so much info not sure what would be the best to build from.
Ty for the info im running heavy (150lbs a corner) 37's on my current axles my dana 30 has 30spline molly shafts so does the 44. Any reason why this wouldnt work on a ZJ?
1994 Grand Cherokee Daily Driver
7" IRO Long arm, 35" Cooper Discrover STT. And more
1993 Wrangler, Rock Smashing Jeep, and November 2012 YJOTM...
1.5" SOA, Stak 3 speed Tcase, 37" Swamper M16's...ALOTS of extras
Pawjob is offline
post #5 of 22 Old 01-19-2013, 07:19 AM
PolkaPower
Medium trail use and a DD on 37's? To me a medium trail would be a 3.5" lift and 32's. A ZJ on 37's would be trailered. I haven't see the IRO long arms in person but I can tell you that the Claytons are pure beef.
PolkaPower is online now
post #6 of 22 Old 01-19-2013, 07:34 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
I'm thoroughly amazed you don't chew through ball joints and unit bearings.
post #7 of 22 Old 01-19-2013, 07:36 AM Thread Starter
Pawjob
Claytons is also 3k not really want to spend that much. Up here in the NW 35's-37's are needed for medium trails. Also my wrangler is on 37's and its a DD.
Ball joints arnt an issue but i go though hubs about every 8-10 months. But they have a 3 year warranty and i just swap them out every 6-8 months. Probaly last little longer if I wasnt banging them around on the rocks.
Pawjob is offline
post #8 of 22 Old 01-19-2013, 08:03 AM
ZeroGravity
So why are Advice if you already know the answers? Anybody is going to tell you 37s are too big for a Dana 30 and a seven inch lift isn't a "mild" build.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #9 of 22 Old 01-19-2013, 08:27 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Agreed.
And you must remember, the grand is a lot heavier than the wrangler. i've seen grands break stuff on 33's that wranglers don't have issues with on 35 & 36's.
And with alloy shafts in there you really need to start worrying about the ring gear in the hp30 over 35's.
post #10 of 22 Old 01-19-2013, 08:39 AM Thread Starter
Pawjob
Agreed.
Really didnt think about the weight of the ZJ ill plan 35's. 33's are little small for around here.
Pawjob is offline
post #11 of 22 Old 01-19-2013, 08:56 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
35s are easily doable. Zjs cost more to lift properly to ensure durability and DD usage.
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #12 of 22 Old 01-19-2013, 09:05 AM
PolkaPower
ZJ's are around 4000 lbs stock. 4.0's are a little lighter. Heaviest would be the 93-95 v8 and the 5.9 right? Probably over 4000 pounds.
post #13 of 22 Old 01-19-2013, 06:05 PM Thread Starter
Pawjob
Thats not bad my wrangler is 4800 with out me in it.
I got a budget of 8k I think I can buy a stock ZJ and build it for that. I already got gears and lockers and I just picked up a HP 30 from a 97 XJ today.
Pawjob is offline
post #14 of 22 Old 01-21-2013, 01:59 PM
JohnnyZJ
you have gears and lockers already anda budget of 8k?
yea, i think you have a chance of pulling that off if you do your work......
07' JKUR rollin on 35s
JohnnyZJ is offline
post #15 of 22 Old 01-21-2013, 02:35 PM Thread Starter
Pawjob
I picked up a HP 30 from a 97 XJ that I plan on swapping my all parts into. And im going to use my XJ Dana 44. They have Eton E locker 30 spline front with molly shafts, Eton E locker rear with 30 spline molly shafts 4.56 gears. Not to mention HID off road lights and the dually LEDs, 17in wheels. I can build my own bumpers and rock rails. Bumpers are cheap i could build both for under 250$. All that plus 8K to buy a ZJ, lift, tires and anything else that comes up. Around here ZJ are cheap i can pick a 96-98 5.2L with 145K-180K miles for under 3K.
Pawjob is offline
