-   -   Looking to start building a ZJ need info (http://www.jeepforum.com/forum/f13/looking-start-building-zj-need-info-1465713/)
Pawjob 01-18-2013 10:26 PM
Like the title says I want to build a ZJ for DD and medium trail use so I can buggy my wrangler. That being said Ive looked at all the ZJ but not sure what model would be the best platform to build on. Ill be swapping my lockers and gears into a XJ HP dana 30 and getting a bracket kit for my Dana 44 rear so axles wont be an issue. Also I was looking at Ironrockoffroad 7" long arm kit. They any good?...I want to clear 35's and would be nice to clear 37's.
xxxxxxxxranger_1999 01-19-2013 05:04 AM
http://www.jeepforum.com/forum/f13/z...u-post-880249/
ratmonkey 01-19-2013 06:49 AM
Clayton long arms
Trim the hell out of your fenders
You can get 35's under there at 4.5".
37's are too much for an hp30/44 set up under a zj.
Buy a 96-98 v8 for your base platform.
Pawjob 01-19-2013 07:03 AM
Originally Posted by ranger_1999 (Post 14814364)
I did read through that but so much info not sure what would be the best to build from.
Ty for the info im running heavy (150lbs a corner) 37's on my current axles my dana 30 has 30spline molly shafts so does the 44. Any reason why this wouldnt work on a ZJ?
PolkaPower 01-19-2013 07:19 AM
Medium trail use and a DD on 37's? To me a medium trail would be a 3.5" lift and 32's. A ZJ on 37's would be trailered. I haven't see the IRO long arms in person but I can tell you that the Claytons are pure beef.
ratmonkey 01-19-2013 07:34 AM
I'm thoroughly amazed you don't chew through ball joints and unit bearings.
Pawjob 01-19-2013 07:36 AM
Claytons is also 3k not really want to spend that much. Up here in the NW 35's-37's are needed for medium trails. Also my wrangler is on 37's and its a DD.
Ball joints arnt an issue but i go though hubs about every 8-10 months. But they have a 3 year warranty and i just swap them out every 6-8 months. Probaly last little longer if I wasnt banging them around on the rocks.
ZeroGravity 01-19-2013 08:03 AM
So why are Advice if you already know the answers? Anybody is going to tell you 37s are too big for a Dana 30 and a seven inch lift isn't a "mild" build.
ratmonkey 01-19-2013 08:27 AM
Agreed.
And you must remember, the grand is a lot heavier than the wrangler. i've seen grands break stuff on 33's that wranglers don't have issues with on 35 & 36's.
And with alloy shafts in there you really need to start worrying about the ring gear in the hp30 over 35's.
Pawjob 01-19-2013 08:39 AM
Originally Posted by ratmonkey (Post 14814819)
Agreed.
Really didnt think about the weight of the ZJ ill plan 35's. 33's are little small for around here.
Texas ZJ1 01-19-2013 08:56 AM
35s are easily doable. Zjs cost more to lift properly to ensure durability and DD usage.
PolkaPower 01-19-2013 09:05 AM
ZJ's are around 4000 lbs stock. 4.0's are a little lighter. Heaviest would be the 93-95 v8 and the 5.9 right? Probably over 4000 pounds.
Pawjob 01-19-2013 06:05 PM
Thats not bad my wrangler is 4800 with out me in it.
I got a budget of 8k I think I can buy a stock ZJ and build it for that. I already got gears and lockers and I just picked up a HP 30 from a 97 XJ today.
JohnnyZJ 01-21-2013 01:59 PM
you have gears and lockers already anda budget of 8k?
yea, i think you have a chance of pulling that off if you do your work......
Pawjob 01-21-2013 02:35 PM
I picked up a HP 30 from a 97 XJ that I plan on swapping my all parts into. And im going to use my XJ Dana 44. They have Eton E locker 30 spline front with molly shafts, Eton E locker rear with 30 spline molly shafts 4.56 gears. Not to mention HID off road lights and the dually LEDs, 17in wheels. I can build my own bumpers and rock rails. Bumpers are cheap i could build both for under 250$. All that plus 8K to buy a ZJ, lift, tires and anything else that comes up. Around here ZJ are cheap i can pick a 96-98 5.2L with 145K-180K miles for under 3K.
The time now is 11:12 AM.
