Looking into buying a Grand Cherokee!!! - JeepForum.com
post #1 of 12 Old 08-02-2009, 04:05 PM Thread Starter
MikeyJ
What things should I look out for? 5.2 vs 4.0 engine differences? Gas mileage? Year models to look for? Any tips would help!!
Been eyeballing this jeep...
http://cosprings.craigslist.org/cto/1289752835.html
Can get it for $1800 and he will give me the front drive shaft (I can install it).... has the 5.2L V8
Its a Laredo too...
Thanks!
MikeyJ is offline
post #2 of 12 Old 08-02-2009, 04:20 PM
salsa
2006 WK
5.2 all the way! Same (if not better) mpg then the 4.0. Does it have select trac? If not the VC in the is probably shot and thats why he took off the front drive shaft. You don't need to take out the front drive shaft in order to tow it. I would probably pass on the one you posted and keep looking.
salsa is offline
post #3 of 12 Old 08-02-2009, 05:51 PM
rustynail
The V8 is what sold me on the Grand Cherokee. I now have a 5.9 ready to go in. I would not consider a 4.0 unless I had no plans to lift or run bigger tires. With the V8 you also get a stronger transmission and rear axle.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #4 of 12 Old 08-02-2009, 05:54 PM
sethjeepwj
2003 WJ
Love mine !!!!!!!!! yay
2003 Jeep Grand Cherokee WJ
4.0L "Work In Progress"
sethjeepwj is offline
post #5 of 12 Old 08-02-2009, 06:02 PM
gatorayde
Unless it's a 93-96 ZJ in which case you still get the turdy five.
And since they drove without a front driveshaft, they ruined the VC in the transfer case so expect a 242 swap in your future if you buy it.
gatorayde is offline
post #6 of 12 Old 08-02-2009, 06:09 PM
rustynail
Oh yeah.... but it's 93-95 not 96.
- Russ
post #7 of 12 Old 08-02-2009, 06:16 PM
gatorayde
Hmm, I thought it was a mid-year switch?
post #8 of 12 Old 08-02-2009, 06:20 PM
rustynail
Maybe so, I'm no expert. I know my '96 has a D44A though.
- Russ
post #9 of 12 Old 08-02-2009, 07:27 PM
befumo
Any engine. Dont get the NP249 (all time 4wd).
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #10 of 12 Old 08-02-2009, 07:28 PM
gatorayde
If you get the V8 it will more than likely come with the 249. A 242 swap is fairly cheap an easy so don't make your decision based on transfer cases.
post #11 of 12 Old 08-02-2009, 07:33 PM
MarkPMB
I wanted the 4.0L, because I knew it was reliable and would last me a very long time. I am not planning on putting larger tires on. already have 245/75-16
and those are fine.
The one thing I knew to stay away from was the dual zone climate control.
So I searched out a 2004 Special Edition package. It gave me all the options I wanted. I am pleased with mine so far.
Good luck.
MarkPMB is offline
post #12 of 12 Old 08-02-2009, 07:33 PM
rustynail
If you really want a V8, get a '96 - '98 because the 249 (full time 4wd) was improved. It is still not great but at least it sends power to the rear all the time unlike '93 - '95.
- Russ
buying 93 grand cherokee johnl30108 ZJ Grand Cherokee Forum 5 08-12-2009 11:27 AM
Buying a 03 Grand Cherokee spreadhead14 ZJ Grand Cherokee Forum 1 04-02-2005 11:51 AM
Help in buying a Grand Cherokee Alex70 ZJ Grand Cherokee Forum 1 01-21-2005 12:38 PM
Buying a 98 Grand cherokee freak4jeeps ZJ Grand Cherokee Forum 3 10-19-2003 07:35 AM
Buying a '99 Grand Cherokee? 98sporttj WJ Grand Cherokee Forum 2 06-02-2003 11:29 AM
