Looking to buy a 97 Grand Cherokee TSi - JeepForum.com
post #1 of 6 Old 05-31-2005, 08:09 AM Thread Starter
rolsen74
I am looking to buy a 1997 Grand Cherokee today and wanted to see what the general opinion would be, I dont want to buy a problem.
Its a 97 GC TSi with the inline six and towing package. 78,055 Miles on it and a recent trade in at the local dealer. The inside is spotless and I have only found a few minor things as bargaining power.
What should I be looking for as potential problems with these models? I have been reading mixed opinions and one major concern is the transmission...seems that there have been problems? I am buying another vehicle because I just lost reverse in my Pathfinder. I want to go back to Jeep again, but I dont want to lose another tranny.
Any advice, suggestions etc would be appreciated....
Also, it seems to have that (common?) exhaust leak until warmed up?
Thanks.
Rob
rolsen74 is offline
post #2 of 6 Old 05-31-2005, 09:01 AM
jbjones1
2 wd or 4 wd if 4 which transfer case? if the 249 (quaratech all time 4wd) do figure 8's in a parking lot and look for any signs of binging in the wheels which means the Viscious coupler is about to be gone.
jbjones1 is offline
post #3 of 6 Old 05-31-2005, 09:26 AM
Derek33
Derek33's Avatar
like he said^ if it has the 249 t-case (4 all time), do figure 8's (or tight turns) in the parking lot and if the wheels skip or bind, then the viscous coupler could be bad (piece in the 249 t-case) and thats about a 1k dollar repair (maybe a bit less)
check the basics irrelevent to just jeeps too. u-joints, cv boots/joints, bushings, exhaust leaks.
i have the same model, except i have the 5.2 motor. great jeep, you'll enjoy it.
Derek33 is offline
post #4 of 6 Old 05-31-2005, 09:39 AM Thread Starter
rolsen74
It is 4wd, but I do not believe that it is the ALL time 4wd, it has the Full and Part time on the shift ? I did not have a spec sheet on the vehicle.
I plan on having them put it up on a lift for me to get a good look under to check the boots and joints.
I do suspect a crack in the header or the connection between the header and pipe. There was slight exhaust noise until the engine warmed.
Any known problems with the rear axles, i "might" have heard a vibration or hum on the rear passenger side...Could have been the tire or possible bearing...but then again I only noticed it once on the test drive.
So the only things i have noticed as "wrong" with it so far is that:
1. When testing the AC (works) and moving the dial to the front vents, it wasnt changing over...it was still blowing out the defrost and floor vents?
2. The exhaust noise.
I also plan on checking the oil and tranny fluid, as they havent changed it so it should be a good check.
They are asking 6495.00 and offering 500 for my "forward driving only" Pathfinder.
What do you think?
rolsen74 is offline
post #5 of 6 Old 05-31-2005, 10:45 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
The right rear noise could also be parking brake pad. the 97s and 98s are pretty good years for ZJs, most of the problems were worked out (typically tranny and heat/AC in eariler model years). you can identify the quadrtrac by TC selector- it has only 4HI, N and 4LO; the selectrack has a 2WD, 4-full time, 4 part time, N, and 4LO positions
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #6 of 6 Old 05-31-2005, 12:12 PM Thread Starter
rolsen74
Excellent. Sounds as though it has the Selectrac . I will still check out the 4 wheel drive though, I didn't have a chance to put it into 4 on the test drive. I'll do that today.
Almost time to leave work and head over
rolsen74 is offline
swapping a grand cherokee rearend for a cherokee dana 44 is it strait bolt in kojak70 ZJ Grand Cherokee Forum 2 11-01-2009 11:44 PM
Will A 242 Transfer Case From A 90 Cherokee Fit In My 99 Jeep Grand Cherokee.?? squirrly ZJ Grand Cherokee Forum 8 03-05-2009 05:55 PM
Trailer Hitch swap from Cherokee to Grand Cherokee hitchikerjoe ZJ Grand Cherokee Forum 4 09-29-2008 05:02 PM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 11:16 AM
Grand Cherokee vs. Grand Wagoneer exhaust Wiley ZJ Grand Cherokee Forum 2 12-31-2005 07:15 PM
