Looking for Advice - JeepForum.com
post #1 of 4 Old 09-21-2007, 03:00 PM Thread Starter
Sandbox
Sandbox's Avatar
Looking for Advice
Hello...Former TJ owner here who's making the jump to the 4 dr Jeep world. Last summer my TJ lost out to my Honda Coupe because of my 120 mile round trip commute with the intentions of buying another one in a year or two.
Well, now we're about to have our 2nd child (a boy this time) and I need 4 doors. So, I'm going to look at a 2000 Grand Limited this weekend. Anything about the WJ's I need to look for or should stay away from? Any advice would be much appreciated!
I does have the 4.7 but, I'm not sure about the rest of the drivetrain.
Thanks again!
Chris
2012 JKU Sport S
2004 WJ 4.7 Limited - SOLD
"DULCE ET DECORUM EST PRO PATRIA MORI"
Sandbox is offline
post #2 of 4 Old 09-21-2007, 03:09 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Blend doors are a very common problem on WJs that have the auto climate control. They control the hot/cold air blend that comes out of the vents. They are inside the heater box so fixing them involves removing the
dash - $800+ at a shop or $120 in parts + a good 8 hours of your time.
The typical symptom they are bad is you'll have no heat, usually on the passenger side only.
You can also check them by running a diagnostic on the climate control system. To do this, hold the a/c and recirc buttons while turning the left temp control knob one click clockwise. Codes will then display. Anything in the 20's or 50's is usually bad news.
Another common problem with the V8 WJs is bearings in the D44a rear axle. Listen for noise coming from this area.
All the other common problems are not deal breakers because they are pretty easily and cheaply fixed.
Wheelin98TJ is offline
post #3 of 4 Old 09-23-2007, 04:19 PM Thread Starter
Sandbox
Sandbox's Avatar
Thanks.....The seller did say that he did some work to the rear axle a bit ago. I will check the blend doors.
2012 JKU Sport S
Sandbox is offline
post #4 of 4 Old 09-29-2007, 02:58 AM Thread Starter
Sandbox
Sandbox's Avatar
So, I tried what you said about checking the codes. A/C and recirc together while turning the left knob one click clockwise. It came up with a 54 but, if you turn the knob again in either direction, it scrolls thru a long list of numbers. Is the list just the possible codes and 54 is just the only active code? Every time I did it, it came up with 54. None of the service guys claimed to know anything about this. It was a Chrysler dealer but not a Jeep Dealer. Maybe that had something to do with it. Any advise?
2012 JKU Sport S
Sandbox is offline
need some advice erinmarie8886 WK Grand Cherokee & XK Commander Forum 3 06-08-2008 04:39 AM
need your advice Casper4x4 ZJ Grand Cherokee Forum 3 06-02-2008 05:02 PM
Advice?? goldenjeep17 ZJ Grand Cherokee Forum 12 12-07-2006 06:56 PM
need advice xtrema391 ZJ Grand Cherokee Forum 2 10-28-2004 08:42 PM
need advice tph ZJ Grand Cherokee Forum 10 10-28-2004 10:51 AM
