Looking for a 5.9 efan shroud - JeepForum.com
post #1 of 10 Old 07-04-2013, 01:46 PM Thread Starter
StPaul59
The PO had a clutch fan installed and of course got rid of the old fan and shroud. I have a shroud right now for a clutch fan, its not even for a jeep, they cut it up to fit. I have a Taurus fan ready to put in but the shroud looks too small for comfort. I want to do it right and get a bigger shroud.
Any ideas??
StPaul59 is offline
post #2 of 10 Old 07-04-2013, 02:21 PM
B93
I've got one (stock 5.9 efan shroud) but shipping from Canada is gonna be expensive.
1998 Grand Cherokee 5.9 Limited. ~356,000 kms
B93 is offline
post #3 of 10 Old 07-04-2013, 06:34 PM Thread Starter
StPaul59
Are we talking over $100? I have no idea what it would cost.
StPaul59 is offline
post #4 of 10 Old 07-05-2013, 08:58 AM
AlphaLorde
Where is st paul are you?
I'm running the taurus fan and taurus shroud. It works awesome!
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #5 of 10 Old 07-05-2013, 02:35 PM Thread Starter
StPaul59
Really? I guess I could try it and see. Ive heard some people complain about the Taurus shroud setup. Im over by Midway stadium.
StPaul59 is offline
post #6 of 10 Old 07-05-2013, 02:40 PM
dnuccio
i ran a taurus fan for a while and it worked great. only reason i took it out was cuz the fan **** the bed (junkyard fan)
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 10 Old 07-05-2013, 02:48 PM
970001zj
t-bird/mk-8 fan fits the radiator perfectly
i got one and its 94* out but i dont even need to engage the high setting
also the wiring has been improved and cleaned up since photos were taken , lol
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #8 of 10 Old 07-05-2013, 05:23 PM
AlphaLorde
Just so you know I had to trim the shroud so it would lay flat against the radiator.
post #9 of 10 Old 07-09-2013, 11:35 PM Thread Starter
StPaul59
I finally completed the Taurus Efan swap tonight and so far so good. I used butt/crimp connectors on the wiring and all is well. I used the GM/Grand National coolant inline hose sensor (WT3000Z) to replace the discontinued stock one in the upper hose for the low speed and it works great with the 180 T stat. Kicks on and off like it should.. Use a 195 T stat and it might stay on most of the time, so I've heard.
The true test will be when its in the mid 80s or higher. Tonight it was in the mid 70s.
I padded and sealed mine with strips of 3/4" foam insulation on the sides and top. I left the bottom alone except for the gap... I covered the gap at the bottom with duct tape
StPaul59 is offline
post #10 of 10 Old 07-10-2013, 12:19 AM
Taz360ZJ
1994 ZJ
I ran that same 3.8L Taurus fan on my old '93 V8 ZJ. Worked great up here in Duluth when it gets to be above 90* w the ac on.
'94 ZJ, AX15, UC+BB, Ravine's, 31's, 3.8L fan, D2S's, fully murdered out.
Taz360ZJ is offline
