#1 | |
Looking for 3" coil spring spacers
Anybody know where I can find 3" coil spring spacers (budget boost) for my 97 ZJ? The largest ones I can find are only 2.125".
[B]1997 Grand Cherokee Laredo 4.0L I6 Rancho RSX shocks[/B] |
#2 |
I don't know if they make a 3 inch. I have the 2 inch on mine it looks good and I was able to fit 31in tires. I shaved the front facia so that there is no rubbing.
[COLOR=darkslategray][FONT=century gothic]1997 Jeep Grand Cherokee Laredo [/FONT] [FONT=century gothic]2 Inch Budget Boost from Rubicon Express[/FONT] [FONT=century gothic]31 Inch Tires, Shaved front facia[/FONT][/COLOR] [COLOR=DarkSlateGray]IMCO Exhaust[/COLOR] [COLOR=DarkRed]Almighty 2" BB Club Member # 38 [/COLOR] |
#3 |
Trust me, you don't want 3 inch spacers on your coils. It will start to handle like a Slinky.
Christian 89 XJ 4.0 AW4 K&N 6x9 cone filter setup Converted to TJ axles - 5-297 U-joints Optima Red Top Custom exhaust www.ishopfaulkner.com |
#4 |
Jeep Jedi Master
You don't want them.
Do you run stock control arms? Have you gotten new shocks because the stockers won't work for that. They are a BAD idea. Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
#5 |
Get 3" coils, not 3" coil spacers, the stock coils are too soft to lift everything up that hight AND the rear coil posts are only2.5" long, so after you put on the spacers, the rear coils would just fall out
#6 |
I've used spacers in the past and don't like them. Can't think of a better way to screw up your handeling and proper functionality of your suspension then to put spacers between the coils which makes them rigid and stops them from doing what they were designed to do, bad idea.
#7 |
Looks like 2.125" are as high as they go for a reason
Could I just get 3" coils and leave it at that and not have to buy a whole 3" lift KIT?
#8 |
Jeep Jedi Master
#9 |
Good Sugestion Hunter.. If you want 3.5 of lift Just take your front coils and put them on the back and then go to ..Kevins Offroad. (formerley Kevins Jeep parts) And buy some 3.5 fronts and a set of shocks.. You are set...
You will need an adjustable track bar or a track bar relocation bracket but that is definatly the cheapest way to go...
Just another soccer moms Grocery getter.... [Url]http://www.jeepforum.com/gallery/files//8/5/6/5/hatt034.jpg[/url] |
#10 |
So...all I have to do is buy a set of 3.5" springs for the front and I'm set?
Why do I not have to do the same for the back? Are the stock front springs equal to 3.5"? Do I need new front AND rear track bars? Also, how can I get away with this setup when everyone I talk to tells me to get a lift KIT? thanks for these awesome suggestions! ![]()
#11 | |
2) only one track bar relocater. 3) you'll need new shocks. stocks are only good for up to 2 inches of lift i believe. 4) not sure but you might need new brake lines in the rear. suggestion: save up and do it right. ![]()
[COLOR=red]1996 jeep grand cherokee 3.5" r.e. superflex lift 31"gdyr mtr's on cragar rockcrawlers olympic xtreme rock rails[/COLOR] [COLOR=white]1997 wrangler 3" teraflex lift w/ jks qiuck disco's 33" bfg mts on black pro comp rockcrawlers 6" extended flairs lod rear bumper w/ tire carrier infinity basslink 10" sub and amp.[/COLOR] [COLOR=blue]the right of the people to keep and bear arms, shall not be infringed[/COLOR] . |
#12 |
which track bar, front or back? or does it even matter.
Also, I just put on Rancho RSX shocks designed for a 3" lift front and back last night. Will those due?
#13 | |
#14 |
Jeep Jedi Master
JC,
get the adjustable front tracbar from RE. BTW, as a parent once asked me, "who is EVERYONE that is telling you that you have to get a kit!" Hunter
#15 |
Friends and people that I know around here have been telling me to get a "kit", but I like the other idea much better.
I'm guess the front springs will give the 3.5" of lift I need in the back b/c they are longer and have to support the weight of the engine?? If I use this set-up, will the Jeep be level?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
