Look what I found - JeepForum.com
post #1 of 22 Old 03-07-2006, 12:39 AM Thread Starter
10achik
I ate what?
10achik's Avatar
Look what I found
It was just sitting there on the porch when I got home tonight, trying to figure out the best place to mount it, I was thinking of mounting it laying flat in the back, but it says not to use it like that, but if I was going to use it I would take it out anyway. Anybody else have a pic of how they mounted theirs?
Oh and the second picture is Keith's fault. He sent me another jeepforum emblem, so you know me, I gotta find a creative spot to put it. I already had the skull there BTW.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #2 of 22 Old 03-07-2006, 12:46 AM
Wiley
Wiley's Avatar
All right! It's always fun finding stuff on the porch. Good luck mounting that beast.
Justin
1993 ZJ Laredo
5.2 V8 4" lift 31s JKS f & r track bars JKS discos Cragar Soft 8s DT 3000s OME Stabilizer
K&N drop-in Dynomax Exhaust Hella 500s Westin Safari Bar KOR Radiator Support
Dark Rosewood Jeep Club Member #5
Wiley is offline
post #3 of 22 Old 03-07-2006, 12:48 AM Thread Starter
10achik
I ate what?
10achik's Avatar
Man, I can always count on you to be up late on the board
Ken
2006 Pontiac G6 GTP
10achik is offline
post #4 of 22 Old 03-07-2006, 12:54 AM
AgitatedPancake
is that a 10lb or 20lb? Either way man...*shivers* I need some sort of OBA =D.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #5 of 22 Old 03-07-2006, 12:55 AM
Wiley
Wiley's Avatar
Yeah, I leave the computer on pretty much all evening. I come back to check it periodically. I probably shouldn't since I always end up staying on until about 1:30 and I have to get up early for work. Oh, well. At least I get caught up on the threads. Wouldn't want to miss the opportunity to learn something!
Justin
1993 ZJ Laredo
Wiley is offline
post #6 of 22 Old 03-07-2006, 01:01 AM Thread Starter
10achik
I ate what?
10achik's Avatar
It's only the 10lb, but it's big enough for me. Really not a bad deal at all, I found it on ebay. There's a guy that sells them brand new for $199, some of his auctions have $30 shipping and some have $18, not sure why. I also picked up a set of the TrailHead tire deflators and calibrated them a few minutes ago, they are set to take my 32's down to 16psi for wheeling.
Absolutely, I learn something knew everyday here, and that's saying something with this group j/k
Ken
2006 Pontiac G6 GTP
10achik is offline
post #7 of 22 Old 03-07-2006, 01:15 AM
AgitatedPancake
You should have learned not to listen to these guys a long ago...
Yeah Im going to try to score a C02 tank sometime soon...incase I pop beads at moab or on the 'con (going out on the rubicon ALOT this summer).THough...there are going to be alot of other things happening to the jeep first.
Build Thread:
post #8 of 22 Old 03-07-2006, 02:42 AM Thread Starter
10achik
I ate what?
10achik's Avatar
You've already got a pretty sweet rig, it can only get better
Ken
2006 Pontiac G6 GTP
10achik is offline
post #9 of 22 Old 03-07-2006, 05:47 AM
Smith Erick
Smith Erick's Avatar
With my co2 Experience from being around Paintball for 6 years and dealing with the small tanks as well as the bulk tanks. I wouldn't reccomend mounting sideways/upside down. In paintball if it is angled downward, the liquid from the co2 with come out as well as the air, so you will be putting water in your tires ...
"Smith Erick"
2004 Jeep Grand Cherokee Special Edition--4.7L V8
15% Tint, Front Tow Hooks, Skid Plates
Yakima Towers and Bars
Uniden Pro510 CB with taillight mounted 3ft. Fire Stik Antenna
Full Aftermarket Infinity Speakers w/ JL 10W7
Kevin's Round Bar Rock Sliderz powdercoated Black
Kevins 2.5 BB w/ Procomp MX-6 shocks
JKS Quicker Disconnects
OME SS
Addco Rear Sway Bar w/ Energy Bushings
TransGo Shift Kit
Kolak Exhaust
15in Crager Streetlocks
31"x10.5" Firestone Destination M/T's
Smith Erick is offline
post #10 of 22 Old 03-07-2006, 05:54 AM
Radiac
Radiac's Avatar
How does the angle of the tank change the CO2 to H2O ?:
His: 2006 Bright Silver Commander
Hers: 2004 Bright Silver Grand Cherokee Laredo
Radiac is offline
post #11 of 22 Old 03-07-2006, 06:26 AM
Smith Erick
Well its not running water, but im sure you don't want any mostiure or liquid in your tires. If you wanted to mount sideways etc you can get a anti-siphon tube which is a copper tube bent upward when you tank is in its mount, therefore letting the gas out, but no liquid.
"Smith Erick"
OME SS
TransGo Shift Kit
Kolak Exhaust
post #12 of 22 Old 03-07-2006, 06:51 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
We use Tim's right side up all the time for tires and air tools and never had anu peoblems with it right side up.
2013 FR-S
BlaineWasHere is offline
post #13 of 22 Old 03-07-2006, 07:00 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
I've got mine bolted to the spare tire anchor (ZJ), but you don't have one. Did you get a mounting rack?
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #14 of 22 Old 03-07-2006, 07:30 AM
GreenDean
GreenDean's Avatar
Any angle over 45 degrees creates magic pixie dust and thus you have water.
Hope this helped.
GreenDean is offline
post #15 of 22 Old 03-07-2006, 08:10 AM
PlatinumZJ
PlatinumZJ's Avatar
It doesn't, BUT if the tank is full and the angle low enough, liquid co2 comes out instead of co2 gas. With the confining pressure removed (somewhere in the 800 to 900 psi range?) the liquid co2 rapidly turns to gas (which absorbs alot of heat).
A fun experiment would be to put liquid co2 into a tire to see if it could blow the tire off the rim - from a GREAT distance of course. Where are the mythbusters when you need them?
Doug
Links:
for ZJ & WJ stuff,
I found a 242 shdybrady19 ZJ Grand Cherokee Forum 28 05-31-2009 10:13 PM
I Think i Found the Right One Mr Q X ZJ Grand Cherokee Forum 3 10-31-2006 05:12 PM
Found My 8.8!!!! randyszj94 ZJ Grand Cherokee Forum 41 10-02-2006 08:50 AM
Found It!!!!! ynotyj ZJ Grand Cherokee Forum 8 03-10-2006 11:32 AM
I found mud jeepholic ZJ Grand Cherokee Forum 4 12-17-2004 07:32 PM
