Longer wheel studs? - JeepForum.com
post #1 of 13 Old 11-11-2013, 08:41 PM Thread Starter
MidCalZJ
Longer wheel studs?
93 zj with front disc and rear drum brake. I installed some wheel spacers from IROs site, the stock studs are not long enough to go thru the spacer and thread all the way into the lugs. The lugs are engaging about 50% of the threads. They torqued fine and i drove short distance with no issue. Would it be ok to stick with the stock studs or do i need to buy longer ones? I went to 2 auto parts stores and a tire shop today and no luck, they had stock length only anything longer changed diameters etc. So, would it be ok to drive on these for now? And where can i get longer studs? The exact part numbers would help. (On my zj, the rear studs are a tiny bit shorter than the front, because of the different brakes.)
93' 4.0 Laredo
4.5" IRO Lift
32x11.5r15 BFG KM2
Temporary sawzall exhaust
MidCalZJ is offline
post #2 of 13 Old 11-11-2013, 08:43 PM
WhiteOut
WhiteOut's Avatar
You'll be fine. You need the same depth of threads engaged as the stud is wide.
Red locktite and torque to 100 foot lbs. Then recheck with the torque wrench set to 90 foot lbs after a couple hundred miles.
WhiteOut is offline
post #3 of 13 Old 11-11-2013, 08:50 PM Thread Starter
MidCalZJ
Great thanks. Was stressing about this. Yep got loctite on em and torqued em to 100 lbs. Will see how she does when i drive to work in the morning
93' 4.0 Laredo
4.5" IRO Lift
32x11.5r15 BFG KM2
MidCalZJ is offline
post #4 of 13 Old 11-12-2013, 08:37 AM
OverlandZJ
Respectfully disagree with WhiteOut.. i don't see how it's acceptable to run like that. I sure as hell wasn't going to.
I ran into this issue also, and swapped in new studs.
http://www.jeepforum.com/forum/f13/h...-stud-1471847/
OverlandZJ is offline
post #5 of 13 Old 11-12-2013, 08:55 AM
PolkaPower
Why would the studs on your 98 be shorter than mine? I never ran into this problem with my spacers. Spider Trax 1.25.
PolkaPower is online now
post #6 of 13 Old 11-12-2013, 08:59 AM
tjkj2002
2002 KJ Liberty
Different front unit bearings may have longer/shorter studs,could have replaced the studs at one time with longer/shorter studs,and some disc brakes have a thicker/thinner mounting surface.
Not all aftermarket parts have identical specs to OE.
tjkj2002 is offline
post #7 of 13 Old 11-12-2013, 09:05 AM
WhiteOut
WhiteOut's Avatar
It follows engineering standards. Same width engagement and a positive lock mechaism.
WhiteOut is offline
post #8 of 13 Old 11-12-2013, 09:06 AM
OverlandZJ
Maybe because it's a 94 XJ HP? That's all i got..
The NAPA longer studs are listed as later model applications.
FWIW my 80's XJ D44 studs were ok for length..
post #9 of 13 Old 11-12-2013, 09:07 AM
PolkaPower
I was talking about your ZJ since we have the same year. An we are both running spider trax from the looks of the blue coating.
post #10 of 13 Old 11-12-2013, 09:10 AM
OverlandZJ
I assume that's a standard that does not consider a wheel spacer that requires locktite for safe useage, in that case i want all the bite i can get.
As in everything else.. YMMV.
post #11 of 13 Old 11-12-2013, 09:11 AM
OverlandZJ
My ZJ has the built HP axle from my old XJ.
post #12 of 13 Old 11-12-2013, 09:16 AM
PolkaPower
Oh thanks. I guess it pays to read haha
post #13 of 13 Old 11-12-2013, 10:01 AM Thread Starter
MidCalZJ
Well i drove to work this morning with no problems. Will drive home this afternoon and check torque.
93' 4.0 Laredo
4.5" IRO Lift
32x11.5r15 BFG KM2
MidCalZJ is offline
