Locking the rear???? - JeepForum.com
post #1 of 7 Old 02-11-2008, 02:27 PM Thread Starter
OnlyJeep4me
Ok, so I did a search on locking the rear and read and read and read and still do not have any clear defined answers in my head.
Can anyone help with this decision? I have a 98 ZJ with a 4.0 and a 35C rear end. The powertrax looks like a very straight forward install unless I am missing something. Is there anything that I need to be aware of?
This is a daily driver that I use for pulling a trailer, boat and fishing and hunting on the weekends. Just do not like getting stuck on the back roads.
OnlyJeep4me is offline
post #2 of 7 Old 02-11-2008, 02:33 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Are you running big tires or basically stock sizes? IF so, you can get a detroit locker or a limited slip for the rear. OR a limited slip for the front and rear. I would suggest that if you are working on the diffs and adding a traction device that if you are planning on regearing in the future to go ahead and do it all at once. That way you aren't covering the same ground twice.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 7 Old 02-11-2008, 02:44 PM
driabyor
driabyor's Avatar
1994 ZJ
powertrax about the same as an aussie ... Isn't it... if so ,then it's way cheaper
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #4 of 7 Old 02-11-2008, 03:07 PM Thread Starter
OnlyJeep4me
Hunter
Just the good ole stockers, 235/15's. The tag on the diff cover was removed before I purchased the vehicle. Is there any way to find out what the gear ratio is?
1998 ZJ Daily Driver
Looking for another Wrangler
1986 Buick Grand National - weekend dragster
post #5 of 7 Old 02-11-2008, 03:23 PM
driabyor
driabyor's Avatar
1994 ZJ
build sheet.... probably a link in the FAQ
5.2 liter 242 :)
driabyor is offline
post #6 of 7 Old 02-11-2008, 03:27 PM
mendelmax
You can find the ratio by rotating the wheel and counting the driveshaft turns.
However, if you are stock, and planning to keep it that way, then maybe as hunter suggested, you may think about LSD? Truetrac for example. It's more friendly on the road, and will help offroad. The only drawback in this situation is the need to set gears when installing, but since you are not touching pinion it's not that hard.
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline
post #7 of 7 Old 02-16-2008, 11:26 PM
hipower47
i installed powertrax no-slip in both my 97 TJ and 02 KJ with no real problem. they work great and you can hole-shot just about anybody from a stop light in a snow storm leaving the slipping and slidding traffic behind. two neg. though, when you backup in an arc (like out of a drive-way) and then go forward, it relocks kind of harshly. the other is when driving straight in snow or any slippery surface it fish-tails very easy if your not careful. i recommend this locker and plan on installing one in my newly aquired 98 ZJ. also easy to install.
dave.
hipower47 is offline
locking rear diff MrWiggles ZJ Grand Cherokee Forum 35 02-04-2009 11:39 PM
locking one axle only -- front or rear? MEinSoCal ZJ Grand Cherokee Forum 16 08-07-2008 10:28 AM
rear axle locking up kdev ZJ Grand Cherokee Forum 4 07-06-2008 01:42 PM
right rear wheel locking up while braking ? jeepunlimited ZJ Grand Cherokee Forum 5 12-22-2007 08:37 PM
Locking Rear Differential jeff_connors ZJ Grand Cherokee Forum 7 10-09-2002 04:25 PM
