Locking Hubs/Transfer Case Swap? - JeepForum.com
post #1 of 30 Old 10-21-2010, 10:11 AM Thread Starter
jczj318
So, I just bought a jeep, and I am trying to get some information. I do not know many of the specifics, (transfer case model, transmission model, axle model) but if someone told me how to find it, I would relate the information if it would be helpful.
The transmission has been changed on the vehicle, as has the engine. It is currently in 2wd, but the 4wd shifter is set to 4wd Full Time. The front drive shaft is not mounted, but I have it. What I want to be able to do, is to be able to switch to awd and back to 2wd without having to mount the drive shaft. I have heard this is possible by either changing the transfer case (probably very expensive) or installing locking hubs. I do not know where to start looking for hubs, and I am unsure how to match a transfer case to this particular transmission. Any advice would be greatly appreciated.
jczj318 is offline
post #2 of 30 Old 10-21-2010, 10:50 AM
Technohead
Originally Posted by jczj318 View Post
. . . What I want to be able to do, is to be able to switch to 4wd and back to 2wd without having to mount the drive shaft. . .
This statement does not make any sense. You must have a driveshaft if you want to switch to 4wd!!!
Sounds to me like the most important question you need answered is why is the front driveshaft removed in the first place. The answer is usually not pretty.
-Eric
Technohead is offline
post #3 of 30 Old 10-21-2010, 11:00 AM Thread Starter
jczj318
Well, the vehicle has quadra-trac I believe, and i was told it was "hopping" on dry tar, so the front drive shaft was taken out, leaving just the rear. hope this helps.
i would be satisfied with AWD (by remounting the front drive shaft) but am discouraged with the "hopping" problem - probably not a good sign.
jczj318 is offline
post #4 of 30 Old 10-21-2010, 11:02 AM
blackjack12982
1994 ZJ
You need to swap the transfer case to a 242 or 231 to have the 2WD option without removing the driveshaft each time. Look through the FAQ's, there's a link in there to email Chrysler. You'll get the build sheet from Chrysler telling you everything you want to know about your ZJm and more.
blackjack12982 is offline
post #5 of 30 Old 10-21-2010, 11:32 AM Thread Starter
jczj318
without having to remount the drive shaft each time i want to switch...
jczj318 is offline
post #6 of 30 Old 10-21-2010, 11:40 AM Thread Starter
jczj318
Also, is it unsafe to drive this vehicle without the front drive shaft mounted? I have seen one other topic that was similar, but it was inconclusive.
jczj318 is offline
post #7 of 30 Old 10-21-2010, 11:51 AM
rugermack
Your VC in your 249 transfer case is going out. That's why it hops. Look for a 242 or 231 transcase.
You can put locking hubs in your jeep, Milemarker and Warn make them. But you will loose your ABS.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #8 of 30 Old 10-21-2010, 11:57 AM Thread Starter
jczj318
I have read that the VC wasn't used in this model jeep. And if I switch to a 242 or 231, is there anything I should know? Am I losing Quadra Trac AWD, and switching to a 4WD/2WD system?
jczj318 is offline
post #9 of 30 Old 10-21-2010, 12:14 PM
Greeeeenberg
249 is fulltime/AWD with power separated by a VC. When slipping occurs it sends power to the front which makes the system go 4wd/awd. When the VC goes it sends power to the front thus creating your wheel hop.
242 - 2wd, 4part-time (snow,mud, gravel, never on pavement), 4wd (anytime, hard on it pavement), and 4low (50/50 lock, offroad only).
Locking hubs why? If you think your gonna gain mileage you wont really. To switch to 4wd all you gotta do is shift transfer case at speeds any lower then 45-50 (except for 4-low).
There are tons of swaps done on here, search 242 Swap and you'll find answers to all your question.
Things you will need to do:
You will need to get drive shaft shortened
Switch a wire in the VIC (Vehicle Info Center) for the dash to read the correct mode
Buy new seal for rear tranny output
Could do seals on t-case
You will want a transfer case outta of 96-98 ZJ. usually paired with the 4.0
Recommendation:
I'd open the case and inspect it
Change fluid
97 ZJ Orvis 5.2 108K.
Member #1
Greeeeenberg is offline
post #10 of 30 Old 10-21-2010, 12:15 PM Thread Starter
jczj318
So, I've looked into some of my options, and I think I would like to swap out the TC for a 242 Select-Trac. How will I know if the one I am going to purchase will fit? Do the engine sizes have to match, or will a 98 GC 4.0, 242 Select-Trac TC not fit?
jczj318 is offline
post #11 of 30 Old 10-21-2010, 12:22 PM
rugermack
There is a good reason to switch to manual locking hubs, it keeps the front bearings from wear out in your d30. There are so many threads on here about worn out front axles. Is it worth the money, that could be debated. Since you can pick up another axle cheap, probably not. In the old days, all the trucks I ever owned had manual hubs, never replaced more than a pinion seal. Even with the TC in 2wd the drive shaft spins and wears out the pinion bearing. Otherwise no one on here would ever replace the pinion bearing, but everyone does.
post #12 of 30 Old 10-21-2010, 12:33 PM
redfoxbody
Locking hubs/unlocking would be sweet but they are a pretty penny.. IMO not worth it if you want to do it for any sort of MPG gain
4.0 2x4>4x4 conversion 3.73, rubicon rims, 245/75R16 mtr 42RE > AX-15 Conversion in progress.
Build thread
Depressed about your car dent? dentszone.com
Nice the legs in that last picture, almost makes you not think about the jeep.
My 16 year old little sister, you creep.
redfoxbody is offline
post #13 of 30 Old 10-21-2010, 12:39 PM
Greeeeenberg
You have an excellent point, but I figured he was doing it because of MPGs, or the fact that his transfer case was blown. I opted for the MPGs.
Also judging by the fact he doesnt want to get out and use re-attach his drive shafts, I'm sure he doesnt want to get out and turn a hub.
Member #1
post #14 of 30 Old 10-21-2010, 12:52 PM Thread Starter
jczj318
This has been helpful, you guys have been great. As far as the locking hubs are concerned, I have not been able to find any for a Jeep Grand at all, let alone my specific model. Is there something I do not know when looking for them? Do I need the whole kit? And what price range are we talking here? I have never owned a car with locking hubs, is there anything I should know?
I do not not mind having to get out and lock them. I am just not very knowledgeable about them.
jczj318 is offline
post #15 of 30 Old 10-21-2010, 01:00 PM
Greeeeenberg
Well someone will correct me if im wrong.
You're gonna need U-joint front axles, and mostly likely you have CVs.
You will need a whole conversion kit.
Cost 600+ i think (just for kit)
If your not doing install add more $$
Member #1
4wd , transfer case swap
manual locking hubs?! 96liftedzj ZJ Grand Cherokee Forum 1 03-22-2010 08:40 PM
WJ Transfer case swap bvark ZJ Grand Cherokee Forum 1 04-10-2007 07:30 PM
Transfer Case Swap ryanp ZJ Grand Cherokee Forum 11 11-03-2006 10:18 PM
Transfer case swap mxz583 ZJ Grand Cherokee Forum 3 11-06-2005 04:55 PM
transfer case swap blackblazer92 ZJ Grand Cherokee Forum 7 05-16-2005 05:16 PM
