Locker - JeepForum.com
post #1 of 11 Old 01-30-2005, 06:49 PM Thread Starter
01grander
Locker
Well im new to the locker market and i was maybe trying to get one for my front dana 30. I wasnt sure what brand and spline? to get. I dont want a ton of noise and im assuming that i will still be hearing noise even when 4wd isnt locked in. If anyone also could tell me a little about the whole spline thing that would be awesome. I can imagine what it is but not specifically. Thanks
01grander is offline
post #2 of 11 Old 01-30-2005, 07:22 PM
demtjcj
first off i would put a locker in the rear before i put one in the front. it just serves more purpose to have one in the rear first. also if you are ordering a locker you can look at the number stamped on your pumpkin. that will tell the seller what axle you have and the ratio you have
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #3 of 11 Old 01-30-2005, 07:34 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
Can't put one in the back of the WJ if you have the D44a. No one makes one that I know of.
2013 FR-S
BlaineWasHere is offline
post #4 of 11 Old 01-30-2005, 07:38 PM Thread Starter
01grander
well i dont want to have a locked rear all the time so i wanted to get the front(cheaper automatic locker) locked. Doesnt detroit make one for the 44 i would imagine somebody does considering that lots of jeeps have 44s?
post #5 of 11 Old 01-30-2005, 07:46 PM
BlaineWasHere
BecauseRacecar
as far as I know they amke em for the 44 but not the 44a.
2013 FR-S
post #6 of 11 Old 01-30-2005, 08:13 PM Thread Starter
01grander
ohhhh i see
post #7 of 11 Old 01-31-2005, 06:04 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I put a detroit trutrac limited slip up front in the dana 30. Works like a champ.
Hunter
I bought it from www.drivetraindirect.com
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 11 Old 01-31-2005, 09:28 AM
PumaZJ
just in response to demtjcj, a locker in the front does 50% more work than a locker in the rear. Alot of comp rigs are allowed to have only one locker and its always a front locker. Instead of pushing the entire weight of the vehicle from the rear tires spinning it is mechanically easier for the locked front to pull the vehicle over objects.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #9 of 11 Old 01-31-2005, 12:23 PM
demtjcj
well most people on here have DD, so therefore it for on road results a rear would be better to have.
demtjcj is offline
post #10 of 11 Old 01-31-2005, 05:35 PM Thread Starter
01grander
I guess i dont know that much about jeep drivetrain. Does the front shaft move and the axle but its just not engaged?(auto hub?) Thats the way my friends trooper is so he had to install manual hubs(AISIN). I hope one day to get mine taller than his....i hope. He has a 97 trooper w/ a 3.5" lift running 33s and the flex on that i havent seen hardly anywhere except really hardcore offroaders. But anyways how much front end chatter will i be hearing if i did the front if at all?
01 Grand Cherokee Laredo 4.0
245/75r16's w/ 2" of lift
ARB and Surco roof rack
Plenty of Hellas.
post #11 of 11 Old 01-31-2005, 09:17 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
The limited slip doesn't chatter at all. I've forgotten that its even there.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
ARB air locker for 44a jhashagen ZJ Grand Cherokee Forum 19 04-07-2008 08:49 PM
Aussie Locker no longer making the D44a locker ArloGuthroJeep ZJ Grand Cherokee Forum 145 03-30-2008 10:26 AM
Which Locker?!?!? JBN311 ZJ Grand Cherokee Forum 18 05-01-2007 01:23 PM
locker ? rustycherokee18 ZJ Grand Cherokee Forum 6 11-16-2006 11:07 AM
ARB locker ??'s PullMeSideways ZJ Grand Cherokee Forum 5 02-23-2006 12:04 AM
